    Jan 10, 2011 @ 16:20
    Anthony Candaele
    how to formate date with xslt
    I'm implementing news functionality for a website.
    In my xslt file, the date is accessed like this:
    <td class="date"><xsl:value-of select="newsDate"/></td>
    This works great but the date rendered on the page is a full date with time part, like this:
    2011-01-10T00:00:00
    I don't need the time part. Does someone know how I can read out the date without the time part, like this:
    2011-01-10
    Thanks for your help,
    Anthony Candaele
    Belgium
  • Comment author was deleted
    Jan 10, 2011 @ 16:22
    Hi Anthony
    You'll need to use an umbraco.library function called FormatDateTime
    Example
    umbraco.library:FormatDateTim($currentPage/@createdate,'dddd dd MMMM yyyy')
    umbraco.library:FormatDateTime($currentPage/@createdate,'dddd dd MMMM yyyy') that is
    Jan 10, 2011 @ 16:23
    Kim Andersen
    Hi Anthony.
    You can try out this:
    <xsl:value-of select="umbraco.library:FormatDateTime(newsDate,'yyyy-MM-dd')"/>
    /Kim A
    Jan 10, 2011 @ 16:32
    Anthony Candaele
    Thanks Tim and Kim, I should have a little more confidence in myself, I tried out an Umbraco library function and solved it like this:
    <td class="date"><xsl:value-of select="Exslt.ExsltDatesAndTimes:date(newsDate)"/></td>
    this gives the following result:
    2011-01-10
    But maybe this format is better:
    10/01/2011
    so I'll use this Umbraco library function suggested by Kim:
    <xsl:value-of select="umbraco.library:FormatDateTime(newsDate,'dd-mm-yyyy')"/>
    hmmm, curious result, I get:
    10-00-2010
    Jan 10, 2011 @ 16:34
    Anthony Candaele
    ok, should have been:
    <xsl:value-of select="umbraco.library:FormatDateTime(newsDate,'dd-MM-yyyy')"/>
    Thanks Kim and Tim for helping me out!
    Anthony
    Jan 10, 2011 @ 17:56
    Kim Andersen
    No problemo Anthony.
    If you want to know more about formatting dates using the FormatDateTime extension, I'd suggest that you read this wiki. There are some good examples, and explanations of how you can achieve the result you want.
    /Kim A
