hello and thanks in advice
is there a way to influence the minimum password requirements for the passwords obtained by the generator?
FAbio
Could you please describe which generator you mean?
Basic asp.net, membership stuff, use web.config to set minimum length of passwords
/Dirk
Pretty obvious, sorry the silly question.
Fabio
Password generator minimum requirements
FAbio
/Dirk
Fabio
