I guess that the alternative links are listed under the Proterties-tab, right? The alternative links are shown when there's set up a/some hostheader(s) on the site that the page is a part of. If you right click the homepage-node and clicks the "Manage hostnames" you should be able to see some hostnames that are attached to this node.
Actually you can edit hostnames on all of your nodes, so maybe it's not the top-node where the hostheaders have been set up, but that's the most normal place to put it.
When you have found the wrong domain-names you can simply delete them from the list.
How to edit alternative links?
I am a newbee, who have 'inherited' a Umbraco site.
One page has a list of "Alternative Links" , but these links are incorrect, and I have to edit them.
How do I edit this list of alternative links for a page?
best regards
Claus Holm, Copenhagen, Denmark
Hi Claus.
Hope this makes sense :)
/Kim A
