How frustrating!
So I have set up my tree structure. On each page I had two properties, a "header" (textstring) and "bodyText (ElasticTextbox from uComponents). They were on a document type that every other page inherited from.
I then deleted these two properties, and added a whole bunch more to a specific document type and saved it.
Now I am getting the same error on every page when I try to access it from the "Content":
Description: An unhandled exception occurred during
the execution of the current web request. Please review the stack trace
for more information about the error and where it originated in the
code.
Source Error:
An unhandled exception was generated during the execution of the current
web request. Information regarding the origin and location of the
exception can be identified using the exception stack trace below.
All good. I've got it working. First, I backed my DB up (for good measure), then went around deleting properties off pages, eventually I removed the offending one, then I had to add them back in, being careful to avoid items that came with uComponents. It seemed to work.
How frustrating!
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Anyone have any ideas? I"ve tried adding the properties back and and I've stopped using ElasticTextBox anywhere...
Thanks in advance.
-Evan
Quite time consuming and annoying though...
