  • Jos Huybrighs 23 posts 55 karma points
    Jan 13, 2011 @ 09:25
    Jos Huybrighs
    Attempt to create a FormattedDateTime macro/xslt
    I am trying to make a macro/xslt that has a 'date' and 'formatString' parameter as input parameters to emit a date string in any format I like according to the .NET format string syntax (e.g. "dd MMMM", ..).
    The invocation of the macro looks as follows (e.g. for @createDate):
    <div class="Date">
      <umbraco:Macro Alias="FormattedDateTime"
    date='<umbraco:Item field="createDate" runat="server" />'
    format="dd MMMM"
    runat="server" />
    My XSLT looks as follows:
    <xsl:output method="xml" omit-xml-declaration="yes"/>
    <xsl:variable name="date" select="/macro/date" />
    <xsl:variable name="formatString" select="/macro/formatString" />
    <xsl:template match="/">
      <xsl:value-of select="umbraco.library:FormatDateTime($date, $formatString)"/>
    </xsl:template
    The problem I have is how to pass a umbraco 'date' attribute/property to the macro. E.g. what should I use as the parameter type for 'date'. It currently is set to 'text' which doesn't seem right to me.
    With the above code nothing is returned in the XSLT because $date apparently is not holding the date that I had expected to be passed with the umbraco:item parameter. When I output $date in the XSLT  file it shows the following:
    <umbraco:Item field="createDate" runat="server"></umbraco:Item>
    Very strange!
    Anyone can help me on this?
    Thanks.
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Jan 13, 2011 @ 09:39
    Richard Soeteman
    I think this is what you want
    date="[#createDate]
    format="dd MMMM"
    runat="server" /
     A parameter can be passed from your document using the [#property name] syntax. If you want to pass a recursive property use [$property name]
    Richard
    Jan 13, 2011 @ 09:59
    Jos Huybrighs
    Thanks Richards. This indeed works. I didn't try this syntax because I thought it could only be used for 'data' aliases, not for node attributes.
