    Jan 13, 2011 @ 11:38
    Anthony Candaele
    properties of file in Media Library
    Is there a place where I can get more information on the properties (xml elements and attributes) of a File in the Media Library?
    I need this information, because I am implementing a 'Documents' page that lists all documents in a 'Documents' folder in the Media Library
    I want to show the title, description and modified date of each document.
    Thanks for your help,
    Anthony Candaele
    Jan 13, 2011 @ 11:47
    Ismail Mayat
    Anthony,
    What version of umbraoc are you using?  In xslt you can do umbraco.library:GetMedia and that will get you the xml for the given file id.  If you do xsl:copy that will dump out the xml structure and you can see what you have out of the box you will get umbracoFile umbracoWidth umbracoHeight and umbracoExtension if you have additional properties added to the file type eg title description then you will see those as well.
    Regards
    Ismail
    Jan 13, 2011 @ 16:24
    Anthony Candaele
    Hi Ismail,
    Thanks for the adivce, I found all the properties I need but one, the createDate attribute of the file element.
    I try to read the createDate attribute like this:
    <td><xsl:value-of select="./file/@createDate" /></td>
    but it doesn't work.
    Anthony
    Jan 13, 2011 @ 16:27
    Anthony Candaele
    I just got it to work like this:
    <td><xsl:value-of select="./@createDate" /></td>
    now I just need to format the date so that I only get the date part without the time part
    Jan 13, 2011 @ 16:29
    Hi Anthony
    You can use the umbraco.library:FormatDateTime() extension to do that. It's very well documented in here: http://our.umbraco.org/wiki/reference/umbracolibrary/formatdatetime
    Jan 13, 2011 @ 16:32
    Anthony Candaele
    Hi Jan,
    Yes, I just got the right dateformat like this:
    <td><xsl:value-of select="umbraco.library:FormatDateTime(./@createDate, 'dd/MM/yyyy')" /></td>
    I'm starting to get the hang of it :)
    Just XPath is still a little difficult for me
