I upgraded v 4.5.2 to 4.6.1. and have some styling issues in the admin interface. For example, the speech bubble is broken, and the new lock screen (re-enter password after inactivity) style seems to be missing. What can I do here?
Just to confirm: I was experiencing the same issue as Andreas. I deleted \App_Data\TEMP\ClientDependency; cleared my browser cache; and edited \config\ClientDependency.config from:
<clientDependency version="1">
to:
<clientDependency version="2">
Indeed, everything is displaying correctly again.
However, are there any other side effects to changing this version? Once it's working, should I change it back to "1"? Will I have to just keep increasing that number with each revision of Umbraco? Thanks
Juno (4.6.1) backend styles
Best Regards,
Andreas
Nobody having the same issues?
May the old styles be cached anywhere? How does DependencyHandler.axd works to generate css?
Best Regards,
Andreas
Removing the App_Data\TEMP directory and browser cache solves this..
You need to change your Client Dependency version, see http://clientdependency.codeplex.com/documentation
This will cause all the CSS and JavaScript cache to be rebuilt
to:
Jonathan
Yes, you should increase it each time you update your CSS or JavaScript.
I suggest you read the CD doco and get an understanding of what it is and why it 'broke' things
