  • Nate 143 posts 184 karma points
    Jan 14, 2011 @ 22:21
    Nate
    runway.gallery.js ?
    I'm on 4.6.1 with a starter skin (personal).  I want to use the lightbox gallery but it says Im missing runway.gallery.js from my scripts folder.  Anyone know where I can grab this?
    Jan 14, 2011 @ 22:37
    Hi Nate
    Have you checked in the scripts folder if it's in fact missing?
    Could be some other stuff that makes it break...if it's missing I don't know if it's possible to simply get the script from codeplex somehow...or maybe you can try to reinstall the package perhaps?
    Jan 14, 2011 @ 22:45
    Nate
    Yes I have checked, it is not there.  I've re-installed the package once and no luck.  Ill look for it in codeplex.
