  • Nigel Wilson 945 posts 2077 karma points
    Jan 16, 2011 @ 08:58
    Nigel Wilson
    Member Records Missing
    Hi there
    I am working on a site where I have loaded 16 member records.
    I am now browsing the member listing in the admin area but can only locate 14 records - there are 2 missing from the list.
    I can however a can log in as one of the missing entries.
    Also the cmsMember table in the database has 16 records - I haven't crossed checked the other tables where member data is stored.
    It is a new site I am setting up using www.softsyshosting.com for the first time.
    Can anyone shed light or experienced this before ?
    Nigel
  • Hendy Racher 863 posts 3849 karma points MVP 2x admin c-trib
    Jan 16, 2011 @ 09:28
    Hendy Racher
    Hi Nigel,
    Can't say I've seen this before, but do the two missing memebers have anything in common ? (do they have spaces at the beginning of their name - wild guess ?)
    Hendy
    Jan 16, 2011 @ 09:33
    Nigel Wilson
    Hi Hendy
    Thanks for your lightning fast reply - you replied too quick as I discovered the error of my ways and attempted to delete my post - your response must have pipped me at the post !
    Within the user control I had misplaced some code which was clearing the "text" field within the umbracoNode table - this effectively hides a member from the listing.
    So by manually re-adding the names all is well. Oh and I have fixed my shinky coding too !
    A lesson in testing your own code but also a bit of understanding of how member lists are built in the back end.
    Cheers
    Nigel
