  • Nate 143 posts 184 karma points
    Jan 17, 2011 @ 03:14
    Nate
    Redirect www.mywebsite.com/index.htm
    I built a new website for someone and I want to put in a 301 for their old hompage which is at /index.htm.
    I tried it through the 301 package and the rewriteurl.config but I'm getting a 404 through IIS 7.  I think it's because IIS is trying to find the htm page before it lands to umbraco.
    I'm on softsys shared hosting.  How do I fix this?
    Thanks!
    Nate
    Jan 17, 2011 @ 20:09
    Nate
    Figured it out.  Added an index.htm page to my site with the following in it.  If someone can reply and confirm that this is correct I will mark them as answered.
    HTTP/1.1 301 Moved Permanently
    <head>
    <title>301 Moved Permanently</title>
    <meta
    http-equiv="Refresh"
    content="0; url=http://www.newwebsite.com">
    </head>
    <body>
    <h1>Moved Permanently</h1>
    <p>The document has moved  <a href="http://www.newwebsite.com">here</a> .</p>
    </body>
    </html>
  • Amir Khan 1289 posts 2746 karma points
    Jan 17, 2011 @ 20:37
    Amir Khan
    Meta refresh is a discouraged method for redirecting, breaks back-button, not a 301 redirect, etc... Something like this in your UrlRewriting.config file would be better (NOTE: not 100% sure how this will work on the SoftSys environment, their tech support is helpful though):
    <add name="some_name"
    redirect="Domain"
    ignoreCase="true" rewriteUrlParameter="IncludeQueryStringForRewrite"
    virtualUrl="/index.htm"
    redirectMode="Permanent"
    destinationUrl="/pathToYourDesiredPage" />
    -Amir
    Jan 17, 2011 @ 20:48
    Nate
    I have that in my URLrewrite config, but IIS serves up a 404 before it reaches umbraco.  That's my original question.
    If I have
    at the top of my HTML redirect page, will that do the 301?
    Jan 17, 2011 @ 21:03
    Amir Khan
    I don't think so...Are you getting a 301 header with that method?
    You may have to adjust a setting in IIS to tell .NET to handle the .html file depending on which version of .NET and web.config you are using. I believe if you're using .NET 4.0 Integrated Pipeline and the correct config files you don't have to modify IIS though.
