  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    Jan 17, 2011 @ 16:00
    Jeroen Breuer
    Dictionary items disappeared
    I've created several dictionary items in Umbraco and now they somehow have disappeared. They don't appear in the settings section anymore, but if I look into the database in the cmsDictionary table all the items appear to be there. Are dictionaries only stored in the database or is a part of it also on the file system? Anyone got an idea what might be wrong?
    Jeroen
    Jan 17, 2011 @ 16:09
    Jeroen Breuer
    Since I still can't edit my first post I'd like to add that I'm using Umbraco 4.5.2.
    Jeroen
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Richard Soeteman
    Hi Jeroen,
    Items are cached and it could be that there went something wrong during load (or save) and then it could be that all items are not loaded. I've seen this once on an install of a client. The UmbracoLog table gave me info what went wrong.
    Richard
    Jan 17, 2011 @ 16:18
    Jeroen Breuer
    I've looked at the error log, but the error doesn't give much information:
    At /umbraco/webservices/TreeDataService.ashx?rnd=2188b3554bd74bd1a9d9412c1608df1e&id=-1&treeType=dictionary&contextMenu=true&isDialog=false&rnd2=88.7 (Referred by: http://localhost:56081/umbraco/umbraco.aspx#settings): ;
    If I try to create a new Dictionary Item I get this error:
    Item has already been added. Key in dictionary: 'Next'  Key being added: 'Next'
    Exception Details: System.ArgumentException: Item has already been added. Key in dictionary: 'Next'  Key being added: 'Next'
    Source Error:
    Stack Trace:
    [ArgumentException: Item has already been added. Key in dictionary: 'Next'  Key being added: 'Next']
       System.Collections.Hashtable.Insert(Object key, Object nvalue, Boolean add) +9360699
       System.Collections.Hashtable.Add(Object key, Object value) +11
       System.Collections.SyncHashtable.Add(Object key, Object value) +78
       umbraco.cms.businesslogic.Dictionary.ensureCache() +384
       umbraco.cms.businesslogic.DictionaryItem.hasKey(String key) +35
       umbraco.dictionaryTasks.Save() +63
       umbraco.presentation.create.dialogHandler_temp.Create(String NodeType, Int32 TypeId, Int32 NodeId, String Text) +619
       umbraco.presentation.create.dialogHandler_temp.Create(String NodeType, Int32 NodeId, String Text) +48
       umbraco.cms.presentation.create.controls.simple.sbmt_Click(Object sender, EventArgs e) +234
       System.Web.UI.WebControls.Button.OnClick(EventArgs e) +118
       System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +112
       System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
       System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
       System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5563
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
    The name of the dictionary item was "DigiTest" which doesn't exist yet. The "Next" key is the first row in the cmsDictionary table.
    If I try to use umbraco.library:GetDictionaryItem with an item that exists in the database I still get nothing back.
    What could be wrong?
    Jeroen
    Jan 17, 2011 @ 16:30
    Richard Soeteman
    Hi Jeroen,
    The error says that the dictionary item next is added multiple times in you database (that was exaclty the error we had). We deleted one record and restarted the app and that was a fix for us, hope it will work in your case also.
    So check your DB for multiple records containing "Next"
    Richard
    Jan 17, 2011 @ 16:53
    Jeroen Breuer
    I couldn't find a duplicate "Next" dictionary item, so I just deleted the only "Next" dictionary item, but that didn't help. Now I get the same exception, but with another dictionary item:
    Item has already been added. Key in dictionary: 'Base.CopyrightNotice'  Key being added: 'Base.CopyrightNotice'
    Exception Details: System.ArgumentException: Item has already been added. Key in dictionary: 'Base.CopyrightNotice'  Key being added: 'Base.CopyrightNotice'
    Source Error:
    Stack Trace:
    [ArgumentException: Item has already been added. Key in dictionary: 'Base.CopyrightNotice'  Key being added: 'Base.CopyrightNotice']
    Still no luck :(.
    Jeroen
    Jan 17, 2011 @ 16:59
    Richard Soeteman
    And you already restarted the site? could it be that there is an empty dictionary item in your db?
    Jan 17, 2011 @ 17:02
    Jeroen Breuer
    Yes I've changed the web.config and the exception still appears. There are some empty rows in the cmsLanguageText table, but that's because not all fields are translated yet. The cmsDictionary table has no empty rows.
    Jeroen
    Jan 25, 2011 @ 17:32
    Jeroen Breuer
    Even after restoring an older database (which used to work) I still get this exception... Will try to restore to an even older database (without dictionaries) to see if that works...
    Jeroen
    Mar 24, 2011 @ 16:19
    Jeroen Breuer
    After 2 months I now have the same exception again on a different website:
    2198925                0              -1            2011-03-24 15:31:38.230                Error      At /umbraco/settings/DictionaryItemList.aspx (Referred by: http://www.../umbraco/):
    2198924                0              -1            2011-03-24 15:31:34.863                Error      At /umbraco/webservices/TreeDataService.ashx?rnd=d0d02972dca94fcca7f63e88b981c998&id=-1&treeType=dictionary&contextMenu=true&isDialog=false&rnd2=82.2 (Referred by: http://www.../umbraco/):d
    Anyone else had this before?
    Jeroen
    Apr 13, 2011 @ 14:15
    Jeroen Breuer
    And now it happend on a third website. Any help would be really appreciated!
    Jeroen
    Apr 13, 2011 @ 14:35
    Jeroen Breuer
    In this third situation I found a duplicate item. After deleting it and recycling the AppPool the dictionary items work again :).
    Jeroen
  • Gerty Engrie 130 posts 490 karma points c-trib
    Apr 13, 2011 @ 16:21
    Gerty Engrie
    Yes, duplicate dictionaryitems! Just track down the duplicate, remove it and all should be ok again :-)
