  • Kyle Skrinak 272 posts 327 karma points
    Jan 17, 2011 @ 17:03
    Kyle Skrinak
    Simple Unversion Package question: "Create an Add element"
    The first step to using Unversion states that one is to "create an add element with the following properties"
    I'm sure this speaks volumes to the cognescenti, but how / where does one "Create an Add element"?
    Thanks!
    Kyle
    Jan 17, 2011 @ 17:12
    Tom Fulton
    Hi Kyle,
    I haven't used the package personally, but I believe it's saying to add this to it's config file, which should be under /config/unVersion.config.  There should already be a sample <add> element defining a simple rule to get started.
    -Tom
    Jan 17, 2011 @ 17:22
    Kyle Skrinak
    Yes, that appears to be it, thanks!
  • TimNape 12 posts 32 karma points
    Mar 30, 2011 @ 12:12
    TimNape
    I have installed it. With the options: <add docTypeAlias="" rootXpath="" maxDays="0" maxCount="0" />
    Suprisingly all versions are still kept
