How to select from thousands of documents in media.
Hello.
I have uploaded approx 100 technical pdf bulletins into the media section of Umbraco 4.5.2.
I have a basic 3 column page, each with a WYSIWYG editor allowing the site owner to create pages and enter content, menus, forms and advertisements without needing to know any code.
I want to create a page that allows the end user to choose and open one of these bulletins. Initially the plan was to create hyperlinks to each pdf and allow the enduser to select from a drop down list.
I am not sure this is the way to go though. It's taken me half my life uploading all those pdfs!
I appreciate your time if you reply but I really must request you treat me like a moron as I have no clue what I am doing, how to write in xslt..etc etc. I'm keen to learn though ;-)
Update: I have managed to write (or copy from some other kind blog post) an XSLT macro that the user can insert in a page and it lists all the documents in that folder.
Now I need to paginate it or something as the page is very long!
Thanks Matt, I wonder if you could offer any more assistance? I am having problems using this for a media node. Here is my code. Can you advise on what I am supposed to put in place of umbraco.library:niceURL? Currently my page is only showing the first 15 items and no next or previous page.
I've not checked it fully yet, but the first thing I've spotted is the numberOfRecords variable. It's currently checking for nodes under current page, rather than in your actual media folder, so I think it will want changing to:
Hello.
Thank you.
Snelbert.
Hey
Checkout this blog post by Tim on doing pagination in XSLT
http://www.nibble.be/?p=11
Matt
{umbraco.library:NiceUrl($currentPage/@id)}/{$pageNumber - 1}">previous</a>
<!DOCTYPE xsl:stylesheet [<!ENTITY nbsp " ">]>
<xsl:stylesheet version="1.0"
<xsl:variable name="documents" select="umbraco.library:GetMedia('1330', 'true')"/>
<xsl:template match="/">
<xsl:variable name="recordsPerPage" select="15"/>
<xsl:variable name="pageNumber">
<xsl:choose>
<xsl:when test="umbraco.library:RequestQueryString('page') <= 1 or string(umbraco.library:RequestQueryString('page')) = '' or string(umbraco.library:RequestQueryString('page')) = 'NaN'">1</xsl:when>
<xsl:otherwise>
<xsl:value-of select="umbraco.library:RequestQueryString('page')"/>
</xsl:otherwise>
</xsl:choose>
</xsl:variable>
<xsl:variable name="numberOfRecords" select="count($currentPage/node)"/>
<xsl:if test="count($documents) > 0">
<ul>
<xsl:for-each select="$documents/* [string(data [@alias='umbracoNaviHide']) != '1']">
<xsl:if test="position() > $recordsPerPage * number($pageNumber - 1) and position() <= number($recordsPerPage * number($pageNumber - 1) + $recordsPerPage )">
<li><a href="{./umbracoFile}" target="_blank"><xsl:value-of select="./@nodeName" /></a></li>
</xsl:if>
</xsl:for-each>
</ul>
</xsl:if>
<xsl:if test="$pageNumber > 1">
<a href="{./umbracoFile}" target="_blank"><xsl:value-of select="./@nodeName" />($currentPage/@id)}/{$pageNumber - 1}">previous</a>
</xsl:if>
<xsl:call-template name="for.loop">
<xsl:with-param name="i">1</xsl:with-param>
<xsl:with-param name="page" select="$pageNumber"></xsl:with-param>
<xsl:with-param name="count" select="ceiling(count($currentPage/node) div $recordsPerPage)"></xsl:with-param>
</xsl:call-template>
<xsl:if test="(($pageNumber) * $recordsPerPage) < ($numberOfRecords)">
<a href="{./umbracoFile}" target="_blank"><xsl:value-of select="./@nodeName" />($currentPage/@id)}/{$pageNumber + 1}">next</a>
</xsl:if>
</xsl:template>
<xsl:template name="for.loop">
<xsl:param name="i"/>
<xsl:param name="count"/>
<xsl:param name="page"/>
<xsl:if test="$i <= $count">
<xsl:if test="$page != $i">
<a href="{umbraco.library:NiceUrl($currentPage/@id)}/{$i}" >
<xsl:value-of select="$i" />
</a>
</xsl:if>
<xsl:if test="$page = $i">
</xsl:if>
</xsl:if>
<xsl:value-of select="$i + 1"/>
</xsl:with-param>
<xsl:with-param name="count">
<xsl:value-of select="$count"/>
</xsl:with-param>
<xsl:with-param name="page">
<xsl:value-of select="$page"/>
</xsl:with-param>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
Hey,
Give that a try, and see if it helps.
Matt
Thanks Matt, it certainly does. I just need to work out how to fix the rest now!
Okay. I admit it, I know nothing about this! Please help?
I can list the first 15 results. I get a next at the bottom of the page but when I click on it I get page does not exisit error.
<xsl:choose>
<xsl:otherwise>
</xsl:otherwise>
</xsl:choose>
</xsl:variable>
<xsl:variable name="numberOfRecords" select="count($documents/*)"/>
<ul>
</xsl:if>
</xsl:for-each>
</ul>
</xsl:if>
<a href="{umbraco.library:NiceUrl($currentPage/@id)}/{$pageNumber - 1}">previous</a>
</xsl:if>
<a href="{umbraco.library:NiceUrl($currentPage/@id)}/{$pageNumber + 1}">next</a>
</xsl:if>
</xsl:template>
</a>
</xsl:if>
</xsl:if>
</xsl:if>
</xsl:with-param>
</xsl:with-param>
</xsl:with-param>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
Hey,
Give this a try
Matt
