  • dominik 711 posts 733 karma points
    Jan 19, 2011 @ 12:01
    dominik
    RSS Feed nodes are not displayed
    I just created a rss feed like it is described in the video.
    the xslt uses:
    <xsl:for-each select="$currentPage/node">
    (like it is done in the video)
    But no items are displayed. I only get a blank RSS site with the site name but without any items (news)
    Can somebody help?
  • Tom Smith 98 posts 172 karma points
    Jan 19, 2011 @ 12:09
    Tom Smith
    Which version of Umbraco are you running?
    The xml scheema has changed in 4.5.2 so you may need to use somthing like
    <xsl:for-each select="currentPage/self::BlogPost">
    If you want to iterate over blog post nodes for example.
    Alternatively this might also work;
    <xsl:for-each select="$currentPage//node [@alias = 'BlogPost']">
    Have you got a link to that video handy? It might be referencing an older version of Umbraco?
    Many Thanks,
    Tom
    Jan 19, 2011 @ 21:50
    Kim Andersen
    Hi Dominik.
    As Tom says the XML schema has changed in the newer versions of Umbraco. If you want to run through nodes with some diferent document types, you have to do like this:
    <xsl:for-each select="$currentPage/*[@isDoc]">
    And if you want to just run through nodes with a document type of "BlogPost", you must do like this:
    <xsl:for-each select="$currentPage/BlogPost">
    /Kim A
    Jan 19, 2011 @ 23:00
    Dennis Aaen
    Hi Dominik and others.
    I just took a look at this post. And really thought I knew the answer as Kim has written in his post. There is something I wonder. Because the way I have asked for a specific document type in Umbraco.
    Are as follows so I thought it would be
    <xsl:for-each select="$currentPage/child::* [@isDoc and self::BlogPost]">
    Maybe it's me who is wrong.
    /Dennis
    Jan 20, 2011 @ 19:54
    Kim Andersen
    Hi Dennis!
    Yeah, your code would work just as well as the other code. But there's no reason to write so much. The following two lines of code would run through the same nodes:
    It's up to you how you want to write your code, but it's always nice to write less code if possible, right ;)
    /Kim A
    Jan 20, 2011 @ 20:08
    Dennis Aaen
    Hi Kim
    Yeah you are right.
    It's nice to write less code if possible ;)
    But I did not know that it was possible to just write
    So thanks Kim ! :)
    /Dennis
    Jan 20, 2011 @ 20:17
    Kim Andersen
    No problem Dennis.
    You can do this because of the way the new schema is structured. I looks something like this:
    <root id="-1">
    <HomePage id="1050" ... >
    <title>My HomePage title</title>
    <BlogPost id="XXXX" ... >
    <title>My first blogpost</title>
    <BlogPost>
    <title>My second blogpost</title>
    <BlogPost>
    etc.
    etc.
    </HomePage>
    </root>
    /Kim A
