  • Kyle Skrinak 272 posts 327 karma points
    Jan 19, 2011 @ 17:44
    Kyle Skrinak
    umbraco and integrated blogging
    In another thread, I've come to learn that umbraco's blog4umbraco package isn't aggressively updated, in fact it is out of sync and "broken" for umbraco version 4.5.2. I'd like to implement a blogging system that will be around, at least for a little while.
    What alternatives should I consider, including replacement models of the "blogging" paradigm?
    Jan 19, 2011 @ 17:55
    Lee Kelleher
    Hi Kyle,
    Blogging options are Umbraco are currently limited to blog4umbraco - or develop your own solution. (If anyone has an alternative suggestion - please say).
    Personally, in terms of a blogging platform - I'd recommend WordPress every time!  But depending on your technology/infrastructure requirements, it might not be an option.  You can install via the Microsoft Web PI: http://www.microsoft.com/web/gallery/WordPress.aspx
    If you were looking for something a little more cutting edge - then take a look at FunnelWeb. One of Umbraco's core developers - Aaron Powell - is also a core developer on FunnelWeb... so you know it's going to be good quality! http://www.funnelweblog.com/
    Cheers, Lee.
  • Tom Smith 98 posts 172 karma points
    Jan 19, 2011 @ 17:56
    Tom Smith
    2
    Well you know my vote ;) I'm sticking up for blog4umbraco (after years of pain working with wordpress) and a good while tweaking blog4umbraco to get it working how I want it.
    Also, the most recent major contributions to the source (in the codegeko branch) have done a lot to make it more stable on 4.5.2
    Alternatively, Umbraco Juno (4.6.1) has a blog starter kit that you can install out of the box that might be worth a look.
    That or wordpress (shudder). (Well to be fair, it's awesome at what it does. I just prefer developing in .NET to php)
    Tom
    Jan 19, 2011 @ 17:58
    Kyle Skrinak
    Thanks, Lee. WP is feature-rich. However, let's say I wanted to post the most recent WP blogpost into the umbraco-sites's homepage. Broadly-speaking, any recommendations?
    Reciprocally, as this site is essentially a brochure-ware site, it begs the question whether the site should simply be a WP site?
    Jan 19, 2011 @ 18:00
    Kyle Skrinak
    Tom: OK! I read the readme for 4.6 and thought that 4.6 wasn't a significant update. I'll update my 4.5.2 site and check it out.
    Thanks!
    Jan 19, 2011 @ 18:02
    Tom Smith
    Eek! I'd try out a fresh install first! An upgrade may well break other things ;)
    Jan 19, 2011 @ 18:05
    Tom Smith
    In answer to getting wordpress to export; this is fairly easy to do with RSS feeds.
    Wordpress outputs a feed of latest posts by default, and umbraco can pick up RSS feeds in a number of ways.
    A quick forum search picked up this one  http://our.umbraco.org/wiki/reference/code-snippets/ironpython-samples/rss-feed
    Tom
    Jan 19, 2011 @ 18:09
    Kyle Skrinak
    Awesome. I like hanging out with smart people. No worries, the site isn't live yet, and I would update a copy to ensure all was well.
    Lee Kelleher
    As well as Tom's suggestion, there are also a few of packages for RSS/Atom feeds: Feed Cache, Feed Viewer and RSS Suite.
    Jan 19, 2011 @ 18:53
    Rich Green
    Does the latest version of Blog4Umbraco have an option to moderate comments *before* they go live?   Don't know too much about the project and not sure why the comments weren't just saved as child nodes to a post which meant we could have used Umbraco's moderation.
    Maybe the version I tried was out of date.
    Rich
    Jan 19, 2011 @ 18:58
    Tom Smith
    Hi Rich,
    No it doesn't. A workaround is to adjust the blog4umbraco core to automatically mark all comments as spam. You can then choose which comments to display on the website by using the comment system to mark them as not spam.
    If you download the latest version of the source, open up the base.cs class in the library folder and add the following line;
                //Set all comments as spam  to allow for moderation
                isspam = true;
    Just below the if (checker!=null) block. Then rebuild the blog4umbraco dll and put it in your website's bin directory.
    All comments will be marked as spam by default, pending your approval.
    Many Thanks,
    Tom
    Jan 19, 2011 @ 19:05
    Rich Green
    Nice tip Tom!
    Many thanks
    Rich
  • jc 64 posts 101 karma points
    Jan 19, 2011 @ 20:51
    Jan 24, 2011 @ 16:00
    Kyle Skrinak
    What an excellent discussion. I will try the blog4umbraco package with the above tweaks. I'd really rather not use WordPress, not as I don't care for the WP (I'm ambivalent) but I'd like the deeper integration via an umbraco-packaged based solution.
