    Jan 20, 2011 @ 11:52
    Anthony Candaele
    link to document: #
    I don't know what happened, but if I look in the properties of a content page, the links of my pages are gone,
    all pages now have a '#' for the 'link to document' value:
    link to document: #
    I have a Umbraco 4.5.2 installation.
    The only thing I know I did was that I restarted sql server
    Anyone else encountered this problem?
    Thanks for your help,
    Anthony Candaele
  • Seth Niemuth 275 posts 397 karma points
    Jan 20, 2011 @ 12:37
    Seth Niemuth
    Have you tried republishing the entire site?
    Jan 20, 2011 @ 13:16
    Anthony Candaele
    Hi Seth,
    Thanks for your advice, I already found the solution here:
    http://our.umbraco.org/forum/templating/templates-and-document-types/12976-Link-to-Document-
    Republishing my home node indeed solved the problem.
    Greetings,
    Anthony
  • Bilal Isa 60 posts 76 karma points
    Jan 22, 2011 @ 23:51
    Bilal Isa
    I'm having the same problem. I tried republishing the whole site and I tried to republish my root node and all childnodes, but the problem persists. When I try to open any page I get a System.ArgumentNullException: Value cannot be null. Parameter name: value. Very strange..
    Jan 23, 2011 @ 14:58
    Seth Niemuth
    Can you see the homepage at all? What happens if you save and publish the homepage (not using the republish the whole site but the save and publish on the toolbar). What do you see for the link to document?
    Jan 23, 2011 @ 15:05
    Bilal Isa
    Hi Seth
    I was seeing Link to document: #. The problem was that I accidentally renamed an app setting in web.config. Sorry for bothering you all with my silly problem :)
    /Bilal
