I am having a terrible time trying to get a page to maintain scroll position on postback. To explain the situation, I have built a user control as a custom datatype that is used on a tab for a page in the umbraco cms back-end (Umbraco 4.5.2). I have searched high and low and tried every suggestion I have seen on the forums.
I have put <pages maintainScrollPositionOnPostBack="true"> in web.config.
I have tried Page.MaintainScrollPositionOnPostBack = true;
I have also tried custom javascript solutions including the SmartScroller control which I modified to get it to work, and whilst I have solved some javascript errors, it now just fails silently :S
Does anyone have any ideas? I am really going nuts with this ... surely something so simple is not impossible with umbraco?
Help! Problem with scroll position
Hi all,
Just incase this helps anyone else. I just had the same issue.
Solution. Find the master page (template) you want to have behave that way and add the following somewhere before the first content control.
<script language="c#" runat="server"> public void Page_Load(object sender, EventArgs e) { Page.MaintainScrollPositionOnPostBack = true; } </script>Hope that helps
I'm having this issue too. Rob, is your lats post you say, "add the following" but there is no following code?
I've created a user control form, inserted it into the page and want it to maintain position on postback. Can't figure it out.
</script%gt;
maybe it looked too much like script :) It hides it unless you add the gt lt escaped code..
Wicked, works great.
