  • dominik 711 posts 733 karma points
    Jan 21, 2011 @ 10:23
    dominik
    translation - stay on current page
    I used the dropdown language selector and it works great.
    But even if i change the language i am redirected to the root page.
    It is neccessary that the user stays on the current page.
    How can i get this working?
    In other CMS (Typo3) there are stored some UIDs for each site and this are connected togehter because the site name can be changed.
    So how can i relate pages (this is possible in umbraco) and use the change language dropdown to connect to the related site?
    Thanks for help
  • Michael Latouche 504 posts 819 karma points MVP 5x c-trib
    Jan 21, 2011 @ 10:52
    Michael Latouche
    Hi Dominik,
    Maybe you can heva a look at the current post: http://our.umbraco.org/forum/developers/api-questions/10603-How-to-relate-pages-in-a-multi-language-site
    I think it contains the information you need about relating multi-lang docs to one another.
    Michael.
    Jan 21, 2011 @ 10:56
    dominik
    ok i found a working solution for connecting parent to child.
    Now i need the same way to connect child back to parent
    Here is the xslt
      <xsl:variable name="relations" select="umbraco.library:GetRelatedNodesAsXml($currentPage/@id)//relation [@parentId = $currentPage/@id]"/>
    <ul>
    <li class="header">Alternative languages</li>
    <xsl:for-each select="$relations">
            <xsl:variable name="url" select="umbraco.library:NiceUrl(@childId)" />
            <xsl:if test="$url != ''">
            <li><a href="{$url}"><xsl:value-of select="./node/@nodeName" /></a></li>
            </xsl:if>
    </xsl:for-each>
    </ul>
