  • dominik 711 posts 733 karma points
    Jan 21, 2011 @ 14:34
    dominik
    Relate more than 2 documents
    Hello
    I try to make a multilingual website (umbraco 4.5.2)
    My navigation structures is:
    - de
    >> products
    >> contact
    - en
    >> products
    >> contact
    - fr
     >> products
     >> contact
    Ive got searched for the following xslt script
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
            version="1.0"
            exclude-result-prefixes="umbraco.library">
    <xsl:param name="currentPage" />
    <xsl:variable name="currentLanguage" select="$currentPage/ancestor-or-self::node[@level = 1]/data[@alias = 'language']" />
    <xsl:variable name="relatedNode" select="umbraco.library:GetRelatedNodesAsXml($currentPage/@id)" />
    <xsl:template match="/">
        <form>
            <select onchange="window.location = this.options[this.selectedIndex].value;">
                    <xsl:for-each select="$relatedNode/relations[relation]">
                            <xsl:attribute name="onchange">
                                    <xsl:text>window.location = '</xsl:text>
                                    <xsl:value-of select="umbraco.library:NiceUrl($relatedNode/relations/relation/node/@id)" />
                                    <xsl:text>'</xsl:text>
                            </xsl:attribute>
                    </xsl:for-each>
                  <xsl:for-each select="$currentPage/ancestor::root/*">
                    <option value="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="language"/></option>
              </xsl:for-each>
            </select>
         </form>
    </xsl:template>
    </xsl:stylesheet>
    This generates a dropdown with 3 options for Germany, English and France
    If i change between 2 languages everything is working fine but how can i use a third language?
    Jan 21, 2011 @ 18:14
    Hi Dominik
    Don't you have three languages on the site already? Is there one of the listed languages it does not switch to? At a first glance of the code I think all you need to do is to just add the new language node in the content section?
    Jan 22, 2011 @ 15:47
    dominik
    Hi Jan,
    If I use two languages the user is able to switch from parent to child.
    But if i use a third language the user is not redirected to the correct child.
    An example
    The user is on
    - de
    >> products
    and clicks "france" he is not send to:
    - fr
    >> products
    So it works if there is only one relation with one child but not if there are two child notes.
    Jan 26, 2011 @ 09:09
    dominik
    Is there no possibilty to relate more than 2 languages?
    How can a multilingual site can be done with more than 2 languages?
    It is necessary that the user will stand on the site he is actual at the moment.
  • Hendy Racher 863 posts 3849 karma points MVP 2x admin c-trib
    Jan 26, 2011 @ 10:18
    Hendy Racher
    Hi Dominik,
    I've not tried the code above, and these thoughts are off the top of my head, so I might be wildly wrong, but I'm guessing that the loop setting the "onchange" attribute for the <select> will only set the "onchange" to the last value in the loop ?
    Just a suggestion, but how about creating a RelationType for each language, and an event on copy that links the two document IDs with the RelationType of the language being copied to ? That way you know from the <select> what language you're swapping to, and can lookup the single related ID for that RelationType.
    Alternatively if using the default "relateDocumentOnCopy" RelationType, then I think you'll have to iterate though each Relation and check to see if it belongs to the path of the tree language being directed to ?
    Hendy
    Jan 26, 2011 @ 10:26
    dominik
    This sounds good but i am new to umbraco and therefor it is very hard to make this modification.
    I used the relation manager to make a new relation.
    Perhaps you are able to tell me how I can add the Event and connect both relation types.
