I think that the language files have disapeared with the new site design on umbraco.org.
However to change the UI language for users you can go to the "users" section and select the default UI language for specific users. However it does not seem like there has yet been made a polish translation.
So if you're up for doing that I think that the Umbraco HQ would like to hear from you.
Ok, then it's possible that the polish language file is already out there somewhere but for some reason just is not a part of the default UI languages. Try shooting the HQ an e-mail about it then.
Language Files - missing?
I am looking for language files for umbraco, escpecially polish translation.
Anybody knows where can i get it?
Mike.
Hi Michal
Hope this helps.
Hi again
The kind mr. Thomas Höhler pointed me in the right direction regarding where the language files can be found.
To find them you need to go to the /umbraco/config/lang folder - here the current translations can be found.
Thanks for your response Jan.
I thought that polish translation was already made, cause I read that smbd already downloaded it:
http://our.umbraco.org/forum/using/ui-questions/5859-umbracoDefaultUILanguage-does-not-change-anything-for-me
I just thought that I am simply unable of finding it on umbraco page. Anybody knows how to get to language files with new umbraco site design?
There is no polish translation under /umbraco/config/lang. So if i get confirmed that it hasnt been done, i think i ll spend some time to do it.
Mike.
Hi Mike
Cheers.
I know it's quite old topic, but i'm facing the same problem today. Is there posibility to find Polish translation right now?
Michael
i'm too interesting polish language file
