  • dominik 711 posts 733 karma points
    Jan 25, 2011 @ 12:35
    dominik
    mark top navigation point
    hello everybody,
    i know how to mark the active navigation point of one site.
    But how can i mark always the top navigation point of each subnavigation item.
    For example
    - Item 1
       - Item 1.1
       - Item 1.2
    If i click on Item 1.2 The main navigation point "Item 1" should be marked as "selected"
    Jan 25, 2011 @ 12:54
    Hi Dominik
    You should be able to achieve this by making this test:
            <xsl:attribute name="class">
              <xsl:if test="@id = $currentPage/ancestor-or-self::node/@id">
                <xsl:text>active</xsl:text>
              </xsl:if>
            </xsl:attribute>
    How does your XSLT look like for now?
    Jan 25, 2011 @ 13:02
    dominik
    Hi Jan,
    Your script also marks only the top if the item is the first subnavigation point.
    It does not work if I use another subnavigation point
    Regards
    Jan 25, 2011 @ 13:05
    dominik
    oh i fixed it by using
    <xsl:if test="current()/@id = $currentPage/ancestor-or-self::*/@id">
    Jan 25, 2011 @ 13:09
    Oops, should have been aware of posting two examples using either old or new schema.
    But you figured it out, so that's good :-)
