  • syn-rg 282 posts 425 karma points
    Jan 27, 2011 @ 05:21
    syn-rg
    Fancybox YouTube IE problem
    I've been trying to play YouTube videos in a Fancybox pop out. It works perfectly in Firefox, Safari and Chrome, but in IE it doesn't display. It will pop out the Fancybox but the video won't display. It only shows [X] (red X in red box).
    Here is the page: http://isis.brandtoolbox.com.au/about-isis/isis-tv.aspx
    Using Firebug I established that it's not displaying the same code as what FF, Safari and Chrome display:
    IE:
    <div id="fancybox-inner" style="top: 0px; left: 0px; width: 640px; height: 360px; overflow: hidden;">
    <object width="640" height="360" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000">
    </object>
    Other browers:
    <param value="http://www.youtube.com/apiplayer?video_id=4haq3C7WwbM&amp;version=3&amp;enablejsapi=1&amp;playerapiid=ytplayer&amp;autoplay=1" name="movie">
    <param value="transparent" name="wmode">
    <embed width="640" height="360" wmode="transparent" type="application/x-shockwave-flash" src="http://www.youtube.com/apiplayer?video_id=4haq3C7WwbM&amp;version=3&amp;enablejsapi=1&amp;playerapiid=ytplayer&amp;autoplay=1">
    </object>
    Here is the XSLT I'm using:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
      exclude-result-prefixes="msxml
    umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes
    Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings
    Exslt.ExsltSets "
    <xsl:param name="maxLevel" select="/macro/maxLevel"/>
    <xsl:variable name="FF_sortType" select="umbraco.library:RequestForm('sortType')" />
    <xsl:variable name="documentTypeAlias" select="string('Video')"/>
    <xsl:template match="/">
    <!-- The fun starts here -->
      <xsl:variable name="level">
        <xsl:choose>
            <xsl:when test="$maxLevel != ''"><xsl:value-of select="$maxLevel" /></xsl:when>
          <xsl:otherwise>6</xsl:otherwise>
        </xsl:choose>
      </xsl:variable>
          <div id="video_list_container">
            <ul>
              <xsl:for-each select="$currentPage/ancestor-or-self::root//* [name() = $documentTypeAlias and string(umbracoNaviHide) != '1']">
                <li>
                  <div class="info">
                    <h1>
                    </h1>
                    <p>
                      <xsl:value-of select="umbraco.library:StripHtml(./videoDescription)" />
                    </p>
                  <a href="http://www.youtube.com/apiplayer?video_id={video}&amp;version=3&amp;enablejsapi=1&amp;playerapiid=ytplayer&amp;autoplay=1"
    id="{video}" class="videoEmbedFancy" onclick="openFancyBoxVideo(this, {videoWidth}, {videoHeight});return false;" title="{@nodeName}">
                    <img width="150" height="113" title="{@nodeName}" src="http://i.ytimg.com/vi/{video}/hqdefault.jpg" />
                    <span>&nbsp;</span>
                    </a>
                </li>
              </xsl:for-each>
            </ul>
    </xsl:template>
    </xsl:stylesheet>
    Jan 27, 2011 @ 08:46
    Hi JV
    It's not because of the code difference in IE and the other browsers that it's not working. IE does not always support the non-standard embed tag, which the other browser do support. For the whole story about this please read this article on alistapart: http://www.alistapart.com/articles/byebyeembed/
    Is it any specific version of IE it is not working in? I've just tried watching the videos in IE8. Seems to be working fine?
    Jan 28, 2011 @ 21:40
    Hi JV
    Did you find a solution for this or did you decide to try another path?
    Jan 31, 2011 @ 04:04
    syn-rg
    Hi Jan
    I've found a solution that works now. I updated the js files to the latest Fancybox js files.
        <!-- jQuery, SWFObject & uTube JS -->
        <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
        <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/swfobject/2.2/swfobject.js"></script>
        <script type="text/javascript" src="/scripts/Designit.VideoEmbed/jquery.mousewheel-3.0.4.pack.js"></script>
        <script type="text/javascript" src="/scripts/Designit.VideoEmbed/jquery.fancybox-1.3.4.pack.js"></script>
        <script type="text/javascript" src="/scripts/Designit.VideoEmbed/FancyBoxInit.js"></script
    The major change was to the FancyBoxInit . js file:
    $(document).ready(function() {
    $("a.videoEmbedFancy").click(function() {
    $.fancybox({
    'padding': 0,
    'autoScale': false,
    'hideOnOverlayClick': false,
    'transitionIn': 'none',
    'transitionOut': 'none',
    'title': this.title,
    'width': 640,
    'height': 360,
    'href': this.href.replace(new RegExp("watch\\?v=", "i"), 'v/'),
    'type': 'swf',
    'swf': {
    'wmode': 'opaque',
    'allowfullscreen': 'true'
    return false;
    This enabled to the YouTube video's to pop out in the Fancybox.
