  • dominik 711 posts 733 karma points
    Jan 27, 2011 @ 09:57
    dominik
    Canvas 4.5.2 Display Problem
    I added a meta description and meta keyword field inside my document type. If i edit the page via canvas he tries to put <strong>Text</strong>. Is there a way to only enable textfields, textareas, headline via canvas?
    Jan 28, 2011 @ 21:54
    Hi Dominik
    So you're able to edit the meta information in canvas mode, right? But for some reason <strong> is placed around the text you're writing in the meta information fields? Is that correctly understood?
    I've tried to find the canvas documentation but it seems to be gone after the conversion to the new site on umbraco.org. Was hoping I could post it since it contains lot's of usefull information about using canvas editing...
    But please try to ellaborate a bit more on the problem you're having and someone might be able to help you out.
