Apologies if this ends up being a newbie question but I am looking to search between a range of values for a property/house search I have implemented using Examine.
I have a form posting values for 'Location' 'Parking' 'NumberOfBedrooms' on the querystring to filter results on the property list page. The Examine index is set up to index properties that have been added to a 'Property' document type (ie Parking field (CheckBox) NumberOfBedrooms(Dropdownlist) etc and I have checked that the indexing is working correctly with LUKE. The search works correctly with all of the above 'text' data type properties and returns the correct properties as I intended.
However I also wish to filter based on the price of the house. So I have a int data type property on the 'Property' document type. This is also being indexed correctly. I then have query string params of 'priceRangeLower' and 'priceRangeHigher' which are retrieved within the property search results user controls. When I try to filter based on these values though I do not get the results I am expecting which the the properties that fall within this range.
The following code is used for the search.
var sc = ExamineManager.Instance.CreateSearchCriteria();
var query = sc.NodeTypeAlias("PropertyDetail");
if (NumberOfBedrooms != String.Empty)
query.And().Field("numberOfBedrooms", NumberOfBedrooms);
if (Location != String.Empty)
query.And().Field("location", Location);
if (Type != String.Empty)
query.And().Field("type", Type);
if (Parking != String.Empty)
query.And().Field("parking", Parking);
if (PriceLower != String.Empty && PriceHigher != String.Empty)
query = query.And().Range("price", PriceLower, PriceHigher, true, true);
query.Not().Field("umbracoNaviHide", "1");
SearchResults = ExamineManager.Instance.Search(query.Compile());
SearchResultListing.DataSource = SearchResults;
SearchResultListing.DataBind();
Thanks in advance if anyone can help me out with where I am going wrong in terms of the range values.
Thanks Ismail, I did see this post but it wasn't apparently obvious where / how the padding takes places. Is there any chance you could give me an example in relation to the code I have posted above.
You will need to implement gatheringnode index and create another field in the index with the padded value and then search on that value my code looks like
public ExamineEvents()
//Add event handler for 'GatheringNodeData' on our 'WOI'
/// get ultimate picker field acutal value not the id of target
/// </summary>
/// <param name="e"></param>
/// <param name="propertyValue"></param>
/// <param name="luceneFieldAlias"></param>
/// <returns></returns>
private string GetFieldValue(IndexingNodeDataEventArgs e, string propertyValue,string luceneFieldAlias)
int nodeId = 0;
int.TryParse(propertyValue, out nodeId);
var n= new Node(nodeId);
//node does not exist but we have numeric value
if(n.Id!=0){
if (NumericProperties.Contains(luceneFieldAlias))
//have to pad out to get lucene range queries to work
int i = 0;
int.TryParse(n.Name, out i);
return i.ToString("D6");
else{
return n.Name;
return nodeId.ToString("D6");
the padding happens in GetFieldValue i have a list of properties already set which contain numeric values that need to be padded out. Dont forget to update your search to search on the padded properties.
This solution appears to work in returning properties with values between £100,000 and £200,000 and for Properties with values between £200,000 and £300,000, however for properties with values of £0 to £100,000 I am getting no results at all when I have two properties at values of £80,000 and £76,000 in this range and fully indexed?
I would test your index using luke and try querying also write out the query that examine is generating and test that in luke. Also what analyser are you using in your examine config if none is provided it defaults to standard if you use whitespace analyser that can give different results on my index i use standard.
I am using the Standard Analyser in the Indexer settings. The following screen grabs highlight in yellow a stripped to the bones query showing it working with 100,00+ values but not working with sub £100,000 values. I'm slightly confused by this.
My code looks as follows, unsure if If using best practice in places but kind of doing this by trial and error at the moment, I have added a screen grab also to show that when I use '080000' I still get no results:
if (Ensuite != String.Empty)
query.And().Field("ensuite", Ensuite);
var paddedLower = int.Parse(PriceLower).ToString("D6");
var paddedHigher = int.Parse(PriceHigher).ToString("D6");
query = query.And().Range("price", paddedLower, paddedHigher, true, true);
var fields = new List<string>();
var values = new List<string>();
//Build up number of bedrooms
if (!String.IsNullOrEmpty(Studio))
fields.Add("numberOfBedrooms");
values.Add("0");
if (!String.IsNullOrEmpty(OneBedroom))
values.Add("1");
if (!String.IsNullOrEmpty(TwoBedroom))
values.Add("2");
if (!String.IsNullOrEmpty(ThreeBedroom))
values.Add("3");
if (!String.IsNullOrEmpty(FourBedroom))
values.Add("4");
values.Add("5");
values.Add("6");
values.Add("7");
if (fields.Count != 0 && values.Count != 0)
var theFields = (fields.ToArray());
var theValues = (values.ToArray());
query.And().GroupedOr(theFields, theValues);
query.And().OrderBy(orderByFields);
var compliedQuery = query.Compile();
SearchResults = ExamineManager.Instance.Search(compliedQuery);
You are missing the GatheringNode code you need to get the value in as D6 as well as querying if you look at my code i have implemented GatheringNode event so that when an indexing event occurs i am injecting in new field which has the value as D6 then i am querying on that. So in my index i have field called participants which has values like 10,11 ,12 etc however i also have a field called __participants this has the padded value e.g. 000010 and I am querying on that. So in your case you need to get values for price in new field call it __price with the padded value then query on that.
Ok Ismail, sorry I have completely missed that. Where abouts in my project do I add the event to inject the new padded field? Can this just be in my SearchResults User Control?
Thanks Ismail, one thing and then I think I'll nearly be there, In terms of the code you sent I'm having issues with e.node.UmbNodeTypeAlias() and node.GetPropertyValue("price") resolving in my class and therefore cannot build and test etc. What other namespaces do I need?
using umbraco.BusinessLogic;
using Examine;
using UmbracoExamine;
using umbraco.presentation.nodeFactory;
using System.Text;
also i am using the latest version of examine from source. What version are you using?
Ok I think the latest version of Examine has sorted that now. You mention that if my ExamineEvents() Class inherits from application base it should be triggered as soon as umbraco is launched however it doesnt seem to be kicking in, so no padding of values can take place and inserted into the index. Do I have to do anything else for this or call this explicitly?
Thanks again.
UPDATE: Dont' worry about this, it is firing now so I will update shortly on progress. Cheers
No, the field is not being added - See Image below:
The code I have in my ExamineEvents Class is now as follows:
using System;
using Examine;
using System.Text;
namespace Client.classes
public class ExamineEvents : ApplicationBase
ExamineManager.Instance.IndexProviderCollection["DemoIndexer"].GatheringNodeData += new EventHandler<IndexingNodeDataEventArgs>(ExamineEvents_GatheringNodeData);
void ExamineEvents_GatheringNodeData(object sender, IndexingNodeDataEventArgs e)
umbraco.NodeFactory.Node theNode = new umbraco.NodeFactory.Node(e.NodeId);
//check if this is 'Content' (as opposed to media, etc...)
if (e.IndexType == IndexTypes.Content)
if (theNode.NodeTypeAlias == "PropertyDetail")
var node = new Node(e.NodeId);
var propertyValue = ExamineEventsHelper.GetPropertyValue(theNode, "price");
if (propertyValue != string.Empty)
e.Fields.Add("__" + "price", GetFieldValue(e, propertyValue, "price"));
AddToContentsField(e);
private void AddToContentsField(IndexingNodeDataEventArgs e)
Dictionary<string, string> fields = e.Fields;
var combinedFields = new StringBuilder();
foreach (KeyValuePair<string, string> keyValuePair in fields)
combinedFields.AppendLine(keyValuePair.Value);
e.Fields.Add("contents", combinedFields.ToString());
private string GetFieldValue(IndexingNodeDataEventArgs e, string propertyValue, string luceneFieldAlias)
int nodeId = 0;
var n = new Node(nodeId);
if (n.Id != 0)
int i = 0;
The following helper class contains the static methods:
using System;
using System.Linq;
using System.Web;
public static class ExamineEventsHelper
public static string GetPropertyValue(umbraco.NodeFactory.Node node, string alias)
return getPropertyValue(node, alias);
private static string getPropertyValue(umbraco.NodeFactory.Node node, string alias)
var property = (umbraco.NodeFactory.Property)node.GetProperty(alias);
return property == null ? string.Empty : property.Value;
I'm hoping that when this is done it will proved a good reference point for other people, once again many thanks.
Kevin
Can you paste your examineindex.config file contents. main point of interest is tag IndexUserFields need to see if that is empty which means all fields get indexed and is all good or you have set the fields manually therefore you also need to set your __price field.
Hi Ismail, as requested. I believe this should be indexing all properties on the document type.
ExamineIndex.config as per tutorial videos:
<?xml version="1.0"?>
Umbraco examine is an extensible indexer and search engine.
This configuration file can be extended to create your own index sets.
Index/Search providers can be defined in the UmbracoSettings.config
More information and documentation can be found on CodePlex: http://umbracoexamine.codeplex.com
<ExamineLuceneIndexSets>
<!-- The internal index set used by Umbraco back-office - DO NOT REMOVE -->
<IndexSet SetName="InternalIndexSet" IndexPath="~/App_Data/TEMP/ExamineIndexes/Internal/">
<IndexAttributeFields>
<add Name="id" />
<add Name="nodeName" />
<add Name="updateDate" />
<add Name="writerName" />
<add Name="path" />
<add Name="nodeTypeAlias" />
<add Name="parentID" />
</IndexAttributeFields>
<IndexUserFields />
<IncludeNodeTypes/>
<ExcludeNodeTypes />
</IndexSet>
<!-- The internal index set used by Umbraco back-office for indexing members - DO NOT REMOVE -->
<IndexSet SetName="InternalMemberIndexSet" IndexPath="~/App_Data/TEMP/ExamineIndexes/InternalMember/">
<add Name="id" />
<add Name="nodeName"/>
<add Name="loginName" />
<add Name="email" />
<IndexUserFields/>
<IncludeNodeTypes/>
</IndexSet>
<IndexSet SetName="DemoIndexSet" IndexPath="~/App_Data/TEMP/ExamineIndexes/DemoIndex/">
<add Name="id" />
<IndexUserFields/>
<IncludeNodeTypes/>
</IndexSet>
</ExamineLuceneIndexSets>
ExamineSettings.config as per tutorial videos
This configuration file can be extended to add your own search/index providers.
Index sets can be defined in the ExamineIndex.config if you're using the standard provider model.
<Examine>
<ExamineIndexProviders>
<providers>
<add name="InternalIndexer" type="UmbracoExamine.UmbracoContentIndexer, UmbracoExamine"
supportUnpublished="true"
supportProtected="true"
interval="10"
analyzer="Lucene.Net.Analysis.WhitespaceAnalyzer, Lucene.Net"/>
<add name="InternalMemberIndexer" type="UmbracoExamine.UmbracoMemberIndexer, UmbracoExamine"
interval="10"
analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net"/>
<add name="DemoIndexer" type="UmbracoExamine.LuceneExamineIndexer, UmbracoExamine"
runAsync="true"
supportUnpublished="false"
interval="10"
indexSet="DemoIndexSet" />
</providers>
</ExamineIndexProviders>
<ExamineSearchProviders defaultProvider="InternalSearcher">
<providers>
<add name="InternalSearcher" type="UmbracoExamine.UmbracoExamineSearcher, UmbracoExamine"
<add name="InternalMemberSearcher" type="UmbracoExamine.UmbracoExamineSearcher, UmbracoExamine"
analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net" enableLeadingWildcards="true"/>
<add name="DemoSearcher" type="UmbracoExamine.LuceneExamineSearcher, UmbracoExamine"
indexSet="DemoIndexSet"/>
</providers>
</ExamineSearchProviders>
</Examine>
ExamineEvents reference to above settings
I am now stumped as that field should now be in the index. Can you try turning of your app pool. Then delete the index folder for DemoIndex then restart the app pool then rebuild the index it may be getting itself in a twist somewhere so this should give us complete new clean index.
Ok I am stumped also, I have deleted the Index and re indexed, no joy. To be sure that I was adding the _price to the correct index aIso added a new property 'KW Test' with a value of 'testing' to the 'PropertyDetail' document type to ensure that this appears in the indexing Node fields in the code and it did. The _price fields gets added to the Indexing Node fields in the code but does not show up in LUKE. So frustrating close to the finishing line, I must have missed a vital something in terms of persisting the value in the index?
one more thing we can try. again delete the index. This time from the root node republish the whole site including child pages, i dont mean republish xml cache but the whole site see if that fixes the problem. Examine generates the index from the xml cache file it may be that the field is not in there (we also have memory cache and it may be there hence you see the field in templates etc) other than this i cant think of anything else.
Ok I tried this and still no joy so I started to inspect the generated index files, I can see the padded values in there but no sign of the __price field, so out of curiosity I changed the field name that was being added to the index to 'kevin'....and BINGO! The padded value appears in the index and is visible in LUKE. Now I have no idea why this is the case but the field name of __price was causing the issue. I can now query the padded values at last. I can't believe it has taken this journey to achieve this functionlity in my app but nevertheless I want to thank you IMMENSELY for your help over the past few days and I hope this thread helps other people out who are trying to achieve a similar range search functionality.
At the risk of almost going insane with this. Now querying the Index from within the website is yielding no results using Examine. The generated lucene query appears to be correct and indeed when I use this query within LUKE the correct results are returned. Any ideas on why this might not be working internally within the site?
{ SearchIndexType: , LuceneQuery: +__NodeTypeAlias:propertydetail +paddedprice:[0 TO 300000] }
in luke which analyser are you using standard or whitespace? Also in the c# code where you build the query pad out the 0 see if that makes a difference. It may be luke is by default padding out?
Was just trying a few different things and found that the default provider was not set to my DemoIndex and as soon as I changed it to this then the results came through. Next onto sorting the results!!! Thanks for your help once again.
Examine Search Range Values
Hi there,
var sc = ExamineManager.Instance.CreateSearchCriteria(); var query = sc.NodeTypeAlias("PropertyDetail"); if (NumberOfBedrooms != String.Empty) { query.And().Field("numberOfBedrooms", NumberOfBedrooms); } if (Location != String.Empty) { query.And().Field("location", Location); } if (Type != String.Empty) { query.And().Field("type", Type); } if (Parking != String.Empty) { query.And().Field("parking", Parking); } if (PriceLower != String.Empty && PriceHigher != String.Empty) { query = query.And().Range("price", PriceLower, PriceHigher, true, true); } query.Not().Field("umbracoNaviHide", "1"); SearchResults = ExamineManager.Instance.Search(query.Compile()); SearchResultListing.DataSource = SearchResults; SearchResultListing.DataBind();Thanks in advance if anyone can help me out with where I am going wrong in terms of the range values.
Kevin
Kevin,
I had similar issue see this post http://our.umbraco.org/forum/developers/extending-umbraco/11819-Examine-range-query-numeric you may need to pad out the data when inserting into the index.
Regards
Ismail
All the best
Kevin
ExamineManager.Instance.IndexProviderCollection[WoiIndexer].GatheringNodeData
+= ExamineEvents_GatheringNodeData;
/// <summary>
/// Event handler for GatheringNodeIndex.
/// This will fire everytime Examine is creating/updating an index for an item
/// </summary>
/// <param name="sender"></param>
if (e.Node.UmbNodeTypeAlias() == ProductAlias)
//if this is a 'product' page look at ultimate picker params
foreach (var ultimateAlias in _ultimatePickerAliases) {
var propertyValue = node.GetPropertyValue(ultimateAlias);
if(propertyValue!=string.Empty)
if(propertyValue.Contains(","))
string[] propValues = propertyValue.Split(new[] {','});
var sbConcatValue=new StringBuilder();
foreach (var propValue in propValues)
sbConcatValue.Append(GetFieldValue(e, propValue, ultimateAlias));
sbConcatValue.Append(",");
e.Fields.Add("__" + ultimateAlias, sbConcatValue.ToString().TrimEnd(','));
else
e.Fields.Add("__" + ultimateAlias,GetFieldValue(e, propertyValue, ultimateAlias));
e.Fields.Add("contents",combinedFields.ToString());
/// <summary>
/// </summary>
int nodeId = 0;
if(n.Id!=0){
int i = 0;
else{
return n.Name;
Regards
Ismail
Hi Ismail,
Many thanks once again for your reply,
Do you have any ideas why this might be?
Kevin
Regards
Ismail
The sub value 80000 should be in the index as 080000 what format are you using in the GatheringNodeEvent I am using ToString("D6");
Regards
Ismail
var query = sc.NodeTypeAlias("PropertyDetail"); if (Location != String.Empty) { query.And().Field("location", Location); } if (Type != String.Empty) { query.And().Field("type", Type); } if (Parking != String.Empty) { query.And().Field("parking", Parking); } if (Ensuite != String.Empty) { query.And().Field("ensuite", Ensuite); } if (PriceLower != String.Empty && PriceHigher != String.Empty) { var paddedLower = int.Parse(PriceLower).ToString("D6"); var paddedHigher = int.Parse(PriceHigher).ToString("D6"); query = query.And().Range("price", paddedLower, paddedHigher, true, true); } var fields = new List<string>(); var values = new List<string>(); //Build up number of bedrooms if (!String.IsNullOrEmpty(Studio)) { fields.Add("numberOfBedrooms"); values.Add("0"); } if (!String.IsNullOrEmpty(OneBedroom)) { fields.Add("numberOfBedrooms"); values.Add("1"); } if (!String.IsNullOrEmpty(TwoBedroom)) { fields.Add("numberOfBedrooms"); values.Add("2"); } if (!String.IsNullOrEmpty(ThreeBedroom)) { fields.Add("numberOfBedrooms"); values.Add("3"); } if (!String.IsNullOrEmpty(FourBedroom)) { fields.Add("numberOfBedrooms"); fields.Add("numberOfBedrooms"); fields.Add("numberOfBedrooms"); fields.Add("numberOfBedrooms"); values.Add("4"); values.Add("5"); values.Add("6"); values.Add("7"); } if (fields.Count != 0 && values.Count != 0) { var theFields = (fields.ToArray()); var theValues = (values.ToArray()); query.And().GroupedOr(theFields, theValues); } query.And().OrderBy(orderByFields); var compliedQuery = query.Compile(); SearchResults = ExamineManager.Instance.Search(compliedQuery); SearchResultListing.DataSource = SearchResults;
Kevin,
Regards
Ismail
In your project create a class
using Examine;
public class ExamineEvents:ApplicationBase
ExamineManager.Instance.IndexProviderCollection["yourindexhere"].GatheringNodeData
then add code to inject the fields see my original code posted earlier. The class inherits from ApplicationBase so its hooked up on site load. Also take a look at demo project code that also shows you how to do it http://www.farmcode.org/post/2010/07/01/Examine-demo-site-source-code-from-CodeGarden-2010.aspx
Regards
Ismail
The GetPropertyValue is an extension in a static class looks like
public static string GetPropertyValue(this Node node, string alias)
return getPropertyValue(node,alias);
private static string getPropertyValue(Node node,string alias)
Property property = node.GetProperty(alias);
The other method is extension method and found in UmbracoExamine.LinqXmlExtensions
Ok cannot find UmbracoExamine.LinqXmlExtensions how do I go about using this? Is this not part of the standard UmbracoExamine.dll
Apologies for the number of questions but I guess thats what this place is for and I need to get this working ASAP. I'm sure its not far off now.
Cheers again
Kevin
Kevin,
In my class i have the following using statements
Regards
Ismail
Thanks again.
did you rebuild the index after deploying your code? As you will need to rebuild so that the values get injected in. you can use http://our.umbraco.org/projects/backoffice-extensions/examine-index-admin to rebuild.
Regards
Ismail
Hi Ismail
I have regenerated the Index and I have stepped through the code and I can see the code is adding the padding as required at the following point
e.Fields.Add("__" + "price", GetFieldValue(e, propertyValue, "price"));However, this new padded value __price doesnt appear in the index when I query it using LUKE after this code has run. Am I missing a final step?
Screenshot below shows the padded value:
kevin,
In luke on the first page do you see under fields the field __price ?
Regards
Ismail
using System; using System.Collections.Generic; using umbraco.BusinessLogic; using Examine; using UmbracoExamine; using umbraco.presentation.nodeFactory; using System.Text; namespace Client.classes { public class ExamineEvents : ApplicationBase { public ExamineEvents() { //Add event handler for 'GatheringNodeData' ExamineManager.Instance.IndexProviderCollection["DemoIndexer"].GatheringNodeData += new EventHandler<IndexingNodeDataEventArgs>(ExamineEvents_GatheringNodeData); } void ExamineEvents_GatheringNodeData(object sender, IndexingNodeDataEventArgs e) { umbraco.NodeFactory.Node theNode = new umbraco.NodeFactory.Node(e.NodeId); //check if this is 'Content' (as opposed to media, etc...) if (e.IndexType == IndexTypes.Content) { if (theNode.NodeTypeAlias == "PropertyDetail") { var node = new Node(e.NodeId); var propertyValue = ExamineEventsHelper.GetPropertyValue(theNode, "price"); if (propertyValue != string.Empty) { e.Fields.Add("__" + "price", GetFieldValue(e, propertyValue, "price")); } } AddToContentsField(e); } } private void AddToContentsField(IndexingNodeDataEventArgs e) { Dictionary<string, string> fields = e.Fields; var combinedFields = new StringBuilder(); foreach (KeyValuePair<string, string> keyValuePair in fields) { combinedFields.AppendLine(keyValuePair.Value); } e.Fields.Add("contents", combinedFields.ToString()); } private string GetFieldValue(IndexingNodeDataEventArgs e, string propertyValue, string luceneFieldAlias) { int nodeId = 0; int.TryParse(propertyValue, out nodeId); var n = new Node(nodeId); //node does not exist but we have numeric value if (n.Id != 0) { //have to pad out to get lucene range queries to work int i = 0; int.TryParse(n.Name, out i); return i.ToString("D6"); } return nodeId.ToString("D6"); } } }The following helper class contains the static methods:
using System; using System.Collections.Generic; using System.Linq; using System.Web; using umbraco.presentation.nodeFactory; namespace Client.classes { public static class ExamineEventsHelper { public static string GetPropertyValue(umbraco.NodeFactory.Node node, string alias) { return getPropertyValue(node, alias); } private static string getPropertyValue(umbraco.NodeFactory.Node node, string alias) { var property = (umbraco.NodeFactory.Property)node.GetProperty(alias); return property == null ? string.Empty : property.Value; } } }I'm hoping that when this is done it will proved a good reference point for other people, once again many thanks. Kevin
Regards
Ismail
Kevin,
Regards
Ismail
kevin,
Regards
Ismail
Thanks again and all the best
Kev
Cool glad to help dont forget to mark solution as solved.
Regards
Ismail
Hi Ismail...once again....
{ SearchIndexType: , LuceneQuery: +__NodeTypeAlias:propertydetail +paddedprice:[0 TO 300000] }in luke which analyser are you using standard or whitespace? Also in the c# code where you build the query pad out the 0 see if that makes a difference. It may be luke is by default padding out?
Regards
Ismail
<ExamineSearchProviders defaultProvider="DemoSearcher"> <providers> <add name="InternalSearcher" type="UmbracoExamine.UmbracoExamineSearcher, UmbracoExamine" analyzer="Lucene.Net.Analysis.WhitespaceAnalyzer, Lucene.Net"/> <add name="InternalMemberSearcher" type="UmbracoExamine.UmbracoExamineSearcher, UmbracoExamine" analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net" enableLeadingWildcards="true"/> <add name="DemoSearcher" type="UmbracoExamine.LuceneExamineSearcher, UmbracoExamine" analyzer="Lucene.Net.Analysis.Standard.StandardAnalyzer, Lucene.Net" indexSet="DemoIndexSet"/> </providers> </ExamineSearchProviders>is working on a reply...
