  • Sherry Ann Hernandez 320 posts 344 karma points
    Feb 01, 2011 @ 15:05
    user control is generating different id
    I have a e-mail subscription user control. When using in different page it is generating different id/name. I'm not sure why it is doing that. Event if the two page is under one masterpage.
    Feb 01, 2011 @ 15:11
    Hi Sherry
    Could you perhaps share some of the code for the user control?
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Feb 01, 2011 @ 20:37
    Richard Soeteman
    Hi Sherry,
    The Id of a usercontrol is dynamic and based on the parentId(s) and the id of the usercontrol itself. Don't assume this id is always the same. This is the way Asp.net works. What do you want to achieve?
    Richard
    Feb 03, 2011 @ 07:55
    Hey guys,
    I just used a class instead to access the control using jquery. I was just wondering why i'm not encountering same issue with my other control.
    Thanks though. :D
  • Michael Latouche 504 posts 819 karma points MVP 5x c-trib
    Feb 03, 2011 @ 09:59
    Michael Latouche
    Hi Sherry,
    Just for your information: if you want to access a server-side user control from client-side code, you can also use the "ClientID" property of your server side control. This will give you the actual ID of your control at the client side, depending of its parents etc. like Richard mentioned.
    Michael.
    Feb 03, 2011 @ 10:11
    Richard Soeteman
    True but you still can't use it in an extenal Javascript file using JQuery. @Sherry, Could be a lot of things causing that. But by default Asp.Net is generating id's for you so better to use Classes instead of id's to ensure you don't run into issues.
    Richard
    Feb 03, 2011 @ 10:19
    Hi Richard and Sherry
    @Richard: In ASP.NET 4 it should be possible to generate a clean id for the HTML, right? I just can't seem to remember the setting at the moment.
    But if one is using 3.5 then classes are the way forward.
    Just a thought.
    Cheers
    Feb 03, 2011 @ 10:26
    Richard Soeteman
    @Jan,
    Yes true, but not everyone is using 4.0
    Feb 03, 2011 @ 10:28
    Michael Latouche
    In Asp.Net 4 I think you can use the ClientIDMode property to specify how the client ID must be generated. Using the "static" value uses the value of the ID attribute: http://msdn.microsoft.com/en-us/library/system.web.ui.control.clientidmode.aspx
    Michael.
    Feb 03, 2011 @ 10:37
    @Richard, true - but just thought it's worth mentioning for future reference if others have a look at this post if they have the same issue :-)
