  • Jonathan Lathigee 56 posts 99 karma points
    Feb 01, 2011 @ 18:18
    Jonathan Lathigee
    Errors importing document type
    I'm exporting document types from one Umbraco install, and attempting to import them into another. The process errors with the following:
    Exception information:
        Exception type: Exception
        Exception message: Could not find datatype with id 05ed6d30-f450-11dd-87af-0800200c9a66.
       at umbraco.cms.businesslogic.packager.Installer.ImportDocumentType(XmlNode n, User u, Boolean ImportStructure)
       at umbraco.presentation.umbraco.dialogs.importDocumentType.import_Click(Object sender, EventArgs e)
       at System.Web.UI.WebControls.Button.OnClick(EventArgs e)
       at System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument)
       at System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument)
       at System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument)
       at System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData)
       at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    This particular document type includes a few custom data types, inclusing the google maps data type and the dynamic data grid. In spite of the error, the document type is added to the system, but those custom data types are missing from its definition. Examining the cmsDataType table in SQL Server shows that, in fact, there *is* an entry for 05ed6d30-f450-11dd-87af-0800200c9a66. It's the google maps data type.
    I have tried hand editing the exported .udt file and removing the reference to the google maps data type, but then the process errors on the *next* custom data type (dynamic data grid), which also (coincidentally) exists in the cmsDataType table.
    I can work around this for now by importing the document type, and then manually re-entering the custom data types, but this is all ground work for a major migration / deploy, and I don't want to be fiddling with dozens of custom data types when it's time to move to prod.
    Any help appreciated
    Jonathan
    Feb 01, 2011 @ 18:19
    Jonathan Lathigee
    oh yeah - should note that it's Umbraco 4.6.1
    Feb 01, 2011 @ 21:43
    Hi Jonathan
    As you're mentioning yourself you need to make sure the datatypes are created otherwise the import of the document *will* fail. It's easy to fix in a minor deploy but it should also be possible to get it wokring smoothlessly on a larger deploy.
    However I must admit that I'm a bit unsure where to look in the database. If you have made custom datatypes using some assembiles and user controls you of course need to copy those over. But I guess some of the .NET gurus in here have some more advice for you.
    Feb 01, 2011 @ 22:37
    Jonathan Lathigee
    Hi Jan, thanks for the reply
    Yes, I should have made clearer, I *did* recreate the data types *before* I tried to import the document types, and I confirmed that they exist in he cmsDataType table with the same guid associated. Perhaps they need to be referenced somewhere else as well?
    Thanks in advance
    Jonathan
