I have a simple "include text" macro that has been tested and is working on several pages. For some reason, on one particular page when we try to insert the macro and save or save/publish, we get an error message. The server log contains the following:
Event Type:Warning
Event Source:ASP.NET 2.0.50727.0
Event Category:Web Event
Event ID:1309
Date:2/1/2011
Time:1:52:02 PM
User:N/A
Computer:CEN-WEB01
Description:
Event code: 3005
Event message: An unhandled exception has occurred.
How many fields does the macro contain of? And is one or more of the possible fields left empty when saving the macro? I suspect that it's maybe because of some validation that does not allow an empty field somehow due to this
Exception message: Length cannot be less than zero.
Or does the field maybe contain a special characther perhaps?
Thanks for the reply, Jan. That was a great stab at the problem, but unfortunately did not help. There is only one field, the node to be included, and it was properly selected. In experimenting, I discovered that I can insert the same macro using the same parameter on other pages in the site with no problem. This page has a few other macros in the same body text field and I'm thinking that something is interfering with this particular one. So I am investigating that scenario. For now, I have provided a workaround so they are happy.
Error saving after macro insert
Event Type: Warning
Event Source: ASP.NET 2.0.50727.0
Event Category: Web Event
Event ID: 1309
Date: 2/1/2011
Time: 1:52:02 PM
User: N/A
Computer: CEN-WEB01
Description:
Event code: 3005
Event time: 2/1/2011 1:52:02 PM
Event time (UTC): 2/1/2011 6:52:02 PM
Event ID: a0951dcfd7bf4d40b02eefeec5168bd5
Event sequence: 13098
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/955224157/Root-2-129410593396663521
Trust level: Full
Application Virtual Path: /
Application Path: E:\InetPub\umbraco schools\
Machine name: CEN-WEB01
Process information:
Process ID: 5504
Process name: w3wp.exe
Account name: NT AUTHORITY\NETWORK SERVICE
Exception information:
Exception type: ArgumentOutOfRangeException
Parameter name: length
Request information:
Request URL: http://schools.fcps.net/umbraco/editContent.aspx?id=1830 ;
Request path: /umbraco/editContent.aspx
User host address: 10.84.4.3
User:
Is authenticated: False
Authentication Type:
Thread account name: NT AUTHORITY\NETWORK SERVICE
Thread information:
Thread ID: 14
Is impersonating: False
Stack trace: at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
at umbraco.editorControls.tinyMCE3.TinyMCE.replaceMacroTags(String text)
at umbraco.editorControls.tinyMCE3.TinyMCE.Save()
at umbraco.controls.ContentControl.saveClick(Object Sender, ImageClickEventArgs e)
at System.Web.UI.WebControls.ImageButton.OnClick(ImageClickEventArgs e)
at System.Web.UI.WebControls.ImageButton.RaisePostBackEvent(String eventArgument)
at System.Web.UI.WebControls.ImageButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument)
at System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument)
at System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Custom event details:
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
We are running umbraco v 4.0.2.1. Any ideas?
Hi Pete
