  • Amigo 245 posts 600 karma points
    Feb 02, 2011 @ 15:05
    Amigo
    images via xsl
    i have the latest version og umbraco installed.
    but i have problems with this xsl:
      <xsl:if test="$mediaNode/umbracoFile">
                            <img src="{$mediaNode/umbracoFile}" alt="[image]" height="{umbracoHeight}" width="{umbracoWidth}" />
                    </xsl:if>
    this is not working:
    i wonder why?
    Feb 02, 2011 @ 15:11
    Tom Fulton
    Try placing $mediaNode before the attributes so it knows where to pull them from:
    alt="[image]" height="{$mediaNode/umbracoHeight}" width="{$mediaNode/umbracoWidth}"
    Feb 02, 2011 @ 15:24
    Amigo
    still not working...
    here is my entire code:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
    <xsl:template match="/">
            <xsl:variable name="mediaId" select="number($currentPage/logo)" />
            <xsl:if test="$mediaId > 0">
                <xsl:variable name="mediaNode" select="umbraco.library:GetMedia($mediaId, 0)" />
                    <img src="{$mediaNode/umbracoFile}" alt="" height="{$mediaNode/umbracoHeight}" width="{$mediaNode/umbracoWidth}" />
            </xsl:if>
    </xsl:template>
    </xsl:stylesheet>
    Feb 02, 2011 @ 15:25
    Tom Fulton
    Which part isn't working?  Is the image showing and the width/height attributes just aren't getting set?
    Feb 02, 2011 @ 15:27
    Amigo
    width and height are empty...
    Feb 02, 2011 @ 15:29
    Tom Fulton
    Hmm, that should work...try re-saving your image in the Media section?
    Otherwise, try outputting the media's XML so we can make sure the values are there:
    <textarea><xsl:copy-of select="$mediaNode"/></textarea>
    Feb 02, 2011 @ 15:35
    Hi Amigo
    Try refreshing the XML cache by choosing "replublish entire site" by right clicking the node named "Content" in the Content section.
    Feb 03, 2011 @ 14:16
    Amigo
    hmmm still not working after refresh and resave image....
    i really wonder why....
    Feb 03, 2011 @ 14:19
    Hi Amigo
    Have you tried to see what XMl you get returned by making a <textarea> with a copy of the variable to see what XML gets returned? If so could you please post the XML in here?
    Feb 03, 2011 @ 14:40
    Amigo
    Hi Jan,
    ok, what i get out is:
    <File id="1053" version="0c10ba34-4fb5-4b66-8cfa-25f40fc0e90b" parentID="1052" level="2" writerID="0" nodeType="1033" template="0" sortOrder="1" createDate="2011-02-02T14:03:51" updateDate="2011-02-02T14:03:50" nodeName="xxx_logo" urlName="xxx_logo" writerName="admin" nodeTypeAlias="File" path="-1,1052,1053"><umbracoFile>/media/44/xxx_logo.jpg</umbracoFile><umbracoExtension>jpg</umbracoExtension><umbracoBytes>21194</umbracoBytes></File>
    Feb 03, 2011 @ 14:44
    Amigo
    Hi Jan,
    Now it works, i renamed the image and uploadet a new one....
    Thanks a lot both of you ;-)
    Feb 03, 2011 @ 15:15
    Hi Amigo
    Happy to hear you got it solved. Sometimes stuff just needs to be refreshed one way or the other and booom! it works :-)
    Remember to mark the post as solved.
