  • Paul A 133 posts 368 karma points
    Feb 02, 2011 @ 18:47
    Paul A
    umbracoReservedPaths prob?
    I'm trying to add a new folder into where Umbraco sits on the server:
    /paul
    I've added in a default.aspx file in there, but it's not being picked up. I get the 404 page.
    I've added the directory to umbracoReservedPaths (triple checked) and have checked that default.aspx is one of the default documents that IIS looks for.
    Am I missing something?
    Feb 02, 2011 @ 18:52
    Hi Paul
    I think you migh also need to add it to the umbracoReservedUrls
    /paul/default.aspx
    Hope this helps.
  • James Patterson 53 posts 192 karma points
    Feb 02, 2011 @ 19:25
    James Patterson
    You should only have to add '~/yourDir/' (~/paul/ in this case) to the umbracoReservedPaths app setting.
    Remember that http://yourdomain.com/paul won't work. But http://yourdomain.com/paul/ (with ending slash) will. Also, the full path .../paul/default.aspx will also work, you shouldn't need to add it to umbracoReservedUrls.
    I just quickly tried this out on my local machine and works as expected.
    James
    Feb 03, 2011 @ 11:19
    Paul A
    Thanks for the repies. I run two umbraco sites... we've been doing this for a while on one site, this is first time on the other.
    /paul/ is working fine (as James pointed out)
    /paul doesn't work... but this does work on the other site just by adding /paul to the umbracoReservedPaths
    Will keep looking around and let you know if I find the fix/problem.
  • Tom Maton 387 posts 660 karma points
    Feb 03, 2011 @ 11:32
    Tom Maton
    Hi Paul,
    Is your umbraco install setup to use friendly urls?
    Tom
    Feb 03, 2011 @ 11:39
    Paul A
    Hi Tom,
    Yup-friendly-URLS-galore.aspx
    (both sites)
    Feb 03, 2011 @ 11:49
    Paul A
    Bingo!
    For some reason, the second site insisted on two bits of info, whereas the first site just needs umbracoReservedPaths.
    Added /directory to umbracoReservedUrls
    Added /directory/ to umbracoReservedPaths
    Cheers for replies,
    Feb 03, 2011 @ 12:27
    Tom Maton
    Glad you got it sorted.
    Tom
    Feb 03, 2011 @ 12:35
    James Patterson
    Nice one. Strange that the two sites had different behaviour though. Something to watch out for.
    James
