    Feb 03, 2011 @ 10:37
    Anthony Candaele
    problems uninstalling blog4umbraco
    Hi, I installed the blog4umbraco package, but after some integration problems with my website, I decided to uninstall the package.
    But now, on the content node I have this error message:
    Could not load control: '/usercontrols/Blog4Umbraco/CommentModeration.ascx'.
    Did anyone had the same problem with uninstalling the blog4umbraco package? How did you solve it?
    Thanks for your help,
    Anthony
    Feb 03, 2011 @ 10:38
    Hi Anthony
    Have you checked the bin folder and the user controls folder to see if the files indeed has been removed during the uninstall process? Sounds like the uninstall did not go well.
    Feb 03, 2011 @ 11:04
    Anthony Candaele
    Hi Jan,
    I already uninstalled a folder blog4umbraco under the usercontrols folder, and removed a blogforumbraco script file under the 'scripts' folder.
    I solved the problem with the content root node though by opening the Dashboard.config file. There where still some blog4umbrac section nodes defined in that file.
    Now my dashboard is back to normal.
    Anthony
    Feb 03, 2011 @ 11:33
    Hi Anthony
    Oh so you did a manual uninstall? Or did you try to run the "uninstall" from the package section and then had to do this cleanup manually? Sounds a bit buggy. Maybe something that should be filed on codeplex?
