  • Jennifer Killingsworth 191 posts 248 karma points
    Feb 04, 2011 @ 17:17
    TinyMCE and Tables
    When you create a table with the rich text editor and save/publish it - any empty TDs disappear.
    I've tried going to the tinyMceConfig.config file and added the # before the td in the validElements entry, as suggested elsewhere on this forum, but it's still not working.
    I'm using Umbraco 4.6.
    Is there something else I need to do?
  • Mike Chambers 636 posts 1253 karma points c-trib
    Feb 04, 2011 @ 21:43
    Mike Chambers
    you might also need to turn of tidy as well..
        <!-- clean editor content with use of tidy -->    <TidyEditorContent>false</TidyEditorContent>
    in config/umbracosettings.config...
  • Doug Mackay 56 posts 155 karma points
    Feb 04, 2011 @ 23:52
    Doug Mackay
    Putting # in front of td (instead of -) and changing entity_encoding from 'raw' to 'named' should fix it.
  • Stuart Burrows 61 posts 110 karma points
    Feb 25, 2011 @ 12:09
    Stuart Burrows
    In my testing I found that changing the entity_encoding to 'named' solved the problem.
    I initially changed - with # for table, td, tr etc but this did not work regardless of what the entity encoding was set to. When I reverted those back to the - but left entity_encoding set as 'named' it all worked as I wanted.
    Hope this helps someone!
