  • Sherry Ann Hernandez 320 posts 344 karma points
    Feb 07, 2011 @ 07:14
    structure site with country folder in multilanguage
    I want my url to be like this
    http://localhost/dining.aspx - > for english site
    http://localhost/ae/dining.aspx -> for arabic site
    I set the hostname of arabic site to localhost/ae/ but even if I navigate to http://localhost/ae
    and I click on dining it always go to http://localhost/dining.aspx
    what am I missing here? why is it is not going to http://localhost/ae/dining.aspx
  • Calvin Frei 106 posts 314 karma points
    Feb 07, 2011 @ 08:12
    Calvin Frei
    Do you set useDomainPrefices to true in the config/umbracoSettings.config?
    <useDomainPrefixes>true</useDomainPrefixes>
    Feb 07, 2011 @ 08:48
    yes I did already. I also change
    add key="umbracoHideTopLevelNodeFromPath" value="false" />
    My Url is now like this
    http://localhost/special-offers.aspx -> english
    http://localhost/ar/special-offers.aspx -> arabic
    But i'm getting an error when trying to access the arabic site. The error is An error occurred while processing your request.
    I check  the umbracologs table and the event viewer but I can't see the actual error from there.
    Feb 07, 2011 @ 08:50
    Calvin Frei
    See my edited post above, did you try this too?
    Feb 07, 2011 @ 09:02
    Hi Sherry
    Hae you added the hostname in Umbraco? And have you added the hostnames in IIS and modified your hosts file to contain the sites as well?
    Feb 07, 2011 @ 09:13
    I already set umbracoHideTopLevelNodeFromPath to false and I added the hostname in umbraco. but in IIS not yet because I can't add the localhost/ar hostname.
    Feb 07, 2011 @ 09:16
    Hi Sherry
    Don't you have access to the hosts file on your local machine? (You are developing locally, right?)
    Feb 07, 2011 @ 09:17
    Calvin Frei
    I mean
    Feb 07, 2011 @ 10:07
    @calvin - yes, I changed it already.
    @jan - I'm getting an error when adding this host header name in the default website http://localhost/ar
    i'm using iis 6.0 in our server I can easily set it up but with my local i'm not sure why i'm getting an error. It doesn't allow to use "/".
    Feb 07, 2011 @ 14:41
    i'm getting this error even if I setup the hostname in the server. I even try republish the site.
    XML Parsing Error: no element found
    Line Number 1, Column 1:
    Feb 07, 2011 @ 14:55
    Anthony Candaele
    Hi Sherry,
    I had the same issues.
    I solved it by adding hostnames like this to my hosts file:
    127.0.0.1 www.flexisle.en.local
    Then I added this binding setting in IIS
    And in 'managing host names' in the Umbraco back office, I entered these settings:
    After that, the link www.flexisle.en.local worked on my local machine.
    greetings,
    Anthony
  • Christer Josefsson 55 posts 93 karma points
    Feb 07, 2011 @ 21:54
    Christer Josefsson
    Anthony´s solution is the way to go when developing locally, #H5YR
    Feb 08, 2011 @ 06:15
    what about when deploying to the server?
    how can I set it up? I'm not really very familiar with this IIS binding.
    in our server we want to host it temporary for testing as
    http://208.75.250.78/default.aspx -> we don't want to use the en folder for the english site
    http://208.75.250.78/ar/default.aspx -> for the arabic site.
    What setup do I need to achieve this?
    Feb 08, 2011 @ 07:18
    Anybody can help setting this up in the server? I've used anthony's advice to set it up in my local machine but for the server i'm still quite confused
    Here's the setup that we want
    Currently we are still using the http://208.75.250.78 address for florahospitality because we haven't launched it yet.
    What we wanted is to setup the multilingual like this
    For English Site
    http://208.75.250.78                          -> This is for english home
    http://208.75.250.78/dining.aspx   -> For other pages
    For Arabic site
    http://208.75.250.78/ar                             -> For arabic home
    http://208.75.250.78/ar/dining.aspx      -> For other pages
    We really need this setup asap.
    Thanks.
