I am digging and digging and not coming up with a clear answer of how to restrict the upload of files and images to the media section in the backend. We need to do a few primary things such as:
Prevent a user from uploading a huge file
Block a user from uploading a restricted file such as an ASP or HTML or Zip file
Allow PDFs up to 5MB but images no larger than 300k
Block images larger than so many pixels
I've tried a few of the add on uploaders but each leaves something out or does not allow restricting the uploads. What are you using? What do you recommend?
Latest advice on how to restrict uploads
