  • Sam 184 posts 209 karma points
    Feb 11, 2011 @ 14:08
    Sam
    Choosing which doctype fields are inherited
    Hi everyone,
    I have a master doctype with the following fields (plus the other meta stuff):
    pageTitle
    mainHeader
    subHeader
    Now, I have a child doctype (lets call it childDoctype1) which only requires:
    pageTitle
    subHeader
    and another called childDoctype2 which requires all three - no problems, all three are inherited! However, for childDoctype1, is there a way of 'unselecting' the mainHeader property (is it a property, or attribute - confused with the jargon still?!). Rather than making a new doctype just because one field should be absent.
    Otherwise, when creating a page using childDoctype1, there will be a field 'mainHeader' that is not required and will just sit there empty.
    As always, any help is very much appreciated! :)
    Sam.
    Feb 11, 2011 @ 20:02
    Hi Sam
    There is no way to deselect an inhertied property as far as I know.
    If you know you need pageTitle and subHeader on all your document types, those are qualified to be set on a master document type. Then you should just add the mainHeader to the document type that needs it. That's how to do it :-)
    I hope it makes sense.
    Cheers
    Feb 11, 2011 @ 20:29
    Sam
    Thanks Jan,
    That makes sense :)
    Sam.
