    Feb 11, 2011 @ 16:11
    Anthony Candaele
    implementing language selector
    I have implemented the language provider as provided by Tim Geysels:
    http://www.nibble.be/?p=32
    The xslt-code for this language selector looks like this:
    <xsl:template match="/">
    <form>
            <select name="langselection" onchange="loadPage(this.form.elements[0])" target="_parent._top">
                <option selected="selected">– Please select –</option>
              <xsl:for-each select="$currentPage/ancestor::root/*">
                  <option value="{umbraco.library:NiceUrl(@id)}">
                      <xsl:value-of select="language"/>
                    </option>
                </xsl:for-each>
            </select>
        </form>
    </xsl:template>
    The problem though with this code is that it gives me the link id for the url and not the 'alternative link'.
    This is a problem for pages from a different language node, but with the same page name.
    For instance consider this site structure
    - en
    .. software
    - nl
    .. software
    The language selector will give me www.mysite.com/software.aspx no mather if I choose the English or Dutch language option.
    Therefore I need to customize the language selection code, so that the value for the language option is preceeded with hostname for the selected language, like www.mysite.com/en/software.aspx or www.mysite.com/nl/software.aspx
    Does anyone has experience with this?
    Thanks for your help,
    Anthony Candaele
    Belgium
    Feb 11, 2011 @ 19:57
    Hi Anthony
    are you using a content-picker for the alternative link? In that case I guess it's simply a matter of passing the id from the alternative link to the NiceUrl and you should be good to go, right?
    Or am I missing something here?
  • Christer Josefsson 55 posts 93 karma points
    Feb 13, 2011 @ 12:28
    Christer Josefsson
    Have you set the the config property (hidetoplevelnodes?) that hides rop lever nodes to false
