I copied an existing Document Type. All ok. Assigned structure, allowed child nodes so I can create document with new document type under old document type. Tried to create a new document based on the new/copied document type. I get this error:
Multiple controls with the same ID 'headline' were found. FindControl requires that controls have unique IDs.
Exception Details: System.Web.HttpException: Multiple controls with the same ID 'headline' were found. FindControl requires that controls have unique IDs.
Source Error:
I just figured it out.. seems to be a bug... I have a master document type with several properties. I have a content document type that inherits from master with none of it's own properties. I make a copy of the content document type. The resulting copy how has all of the properties of the master! It did not make an exact copy. Instead it made a copy of the source document type along with every document type it inherits from.
Multiple controls with the same ID ...
Source Error:
