    Feb 11, 2011 @ 16:59
    Anthony Candaele
    multilanguage site with duplicate page names
    Anyone faced the problem, where your multilanguage site had duplicate page names, for instance:
    -en
    .. software
    - nl
    .. software
    The navigation in my multilingual website returns in both cases the url:
    www.mysite.com/software.aspx
    while it should return:
    www.mysite.com/en/software.aspx
    or
    www.mysite.com/nl/software.aspx
    How did you tackle this problem?
    Thanks for your advice
    Anthony Candaele
    Belgium
  • Kyle Skrinak 272 posts 327 karma points
    Feb 12, 2011 @ 14:42
    Kyle Skrinak
    I'm not clear on all the details, but here's how I do this in one 7 language site I manage:
    Each language's content is in its own branch, i.e. in the content pane,
    en
    1.aspx
    2.aspx
    3.aspx
    es
    1.aspx
    2.aspx
    3.aspx
    and the "manage hostnames" per branch is set accordingly, i.e.,
    en ← widgets.com/en
    es ← widgets.com/es
    hth; Kyle
    Feb 12, 2011 @ 14:51
    Anthony Candaele
    Hi Kyle,
    I'll try out your example, and let you know if it worked for me.
    Thanks for your advice,
    Anthony
    Feb 12, 2011 @ 15:24
    Kim Andersen
    Hi Anthony
    You might want to check the web.config out as well. Find this:
    <add key="umbracoHideTopLevelNodeFromPath" value="true" />
    and change it to this:
    <add key="umbracoHideTopLevelNodeFromPath" value="false" />
    This should tell Umbraco NOT to hide the top level node from the URL.
    /Kim A
    Feb 12, 2011 @ 15:32
    Anthony Candaele
    Thanks Kim for the tip!
    greetings,
    Anthony
    Feb 12, 2011 @ 15:38
    Kim Andersen
    You are welcome Anthony. Did it solve your problem?
    /Kim A
    Feb 12, 2011 @ 15:43
    Anthony Candaele
    Hi Kim,
    I just tried your suggestion an it solved the problem! Thanks a lot, this really makes my day :)
    Anthony
    Feb 12, 2011 @ 15:45
    Kim Andersen
    Well isn't that just great :)
    I'm glad to hear so Anthony. Have a nice day!
    /Kim A
  • Sherry Ann Hernandez 320 posts 344 karma points
    Feb 14, 2011 @ 11:52
    i'm also having an issue with this one. Even if I set the hostname accordingly it is still not displaying my pages properly.
    My config is as follows (Please note that we are still using the ip address because this is for testing purpose.)
     en -> 208.75.250.78
        page1.aspx
        page2.aspx
    ar -> 208.75.250.78/ar
        page1.aspx
        page2.aspx
    This setup is working on my local machine. I followed the example in the other forum post to set en.local/ar.local but when I uploaded it our server and change the hostname. that's the time we encounter the problem.
    I've been trying to fix this for 4 days now and would really need some help. I also e-mail umbraco (we have umbraco pro license) but I haven't got any detailed answer from them.
