I've just noticed in the properties tab today that the link to document on my homepage is //
When clicked on in the cms, this obviously doesn't load my homepage correctly. Is there a reason why this would have happened? I have tried republishing but no change. Shouldn't this link should be a single slash /
Link to document //
Hi everyone,
Thanks in advance if anyone can help :)
Sam.
Hi Sam
That's odd...it should only be /
I guess it's 4.6.1 you're running?
Have you done anything special on this installation?
Hi Jan,
Yes, I'm on 4.6.1. I have a subdomain with umbraco installed but would that cause this?
I did a clean install for this. I could always try again, the database is backed up, as are my master templates, doctypes, css etc.
Maybe it's the URL rewrite in my web.config?
Sam.
I'm guessing it's this bug which looks like it was fixed and coming in 4.6.2. Something to do with the new addTrailingSlash I would imagine.
-Tom
Thanks Tom,
I think you may be right :)
Sam.
