  • manwood 87 posts 109 karma points
    Feb 19, 2011 @ 11:19
    manwood
    Is there a quick way to bulk-delete content?
    I have a site that gets updated annually. I want to clear out all of last years content but leave the structure in place. Is there an easy way to do this? Manually deleting content nodes one by one will take me an epoch...
    thanks
    Feb 19, 2011 @ 14:25
    Kim Andersen
    Hi Manwood.
    The nodes that you want to delete, are they stuffed under the same parent node? If that's the case, you can just delete this node and the childnodes are deleed as well.Not sure if that's how you have structured your content even though it sounds like it would be a good idea :)
    /Kim A
  • Felix Ivan Romero Rodríguez 4 posts 24 karma points
    Jan 24, 2024 @ 18:14
    How to do it by code on Umbraco 10?
  • Simon Napper 116 posts 370 karma points
    Jan 25, 2024 @ 14:07
