  • greengiant83 88 posts 109 karma points
    Feb 22, 2011 @ 19:41
    greengiant83
    Empty recycling bin hangs
    I have a fresh install of umbraco 4.6.1 (Assembly version: 1.0.4029.25836) I have about 3500 items in the recycling bin. When I tell it to empty the bin it hangs on the "The items in the recycle bin is now being deleted" dialog. I left in running all morning (4 hours or so) and it doesn't appear to have deleted even one. What could be the problem?
    Feb 22, 2011 @ 21:02
    Hi Greengiant83
    Hmm, that's odd...
    Could this perhaps be a permission issue?
    Feb 22, 2011 @ 21:05
    greengiant83
    I am not sure how it could be. I am logged in as the default admin user trying to do the delete. So I should have all the permissions I need there. As for the phyiscal folder on the file system, I gave Everyone full control, so it shouldnt be a file system permissions issue. The app's connection string is connecting to the database via the SA account so there shouldnt be any issue there either.
    Can you think of any other places to check?
    Feb 22, 2011 @ 22:17
    greengiant83
    I don't know why it is hanging, but I got the trash can emptied by manually removing the content from the database tables by executing this sql for each record in the umbracoNode table where parentID = -20
      delete from [Umbraco].[dbo].cmsDocument where nodeId = 123
      delete from [Umbraco].[dbo].cmsContentXml where nodeId = 123
      delete from [Umbraco].[dbo].cmsPreviewXml where nodeId = 123
      delete from [Umbraco].[dbo].cmsPropertyData where contentNodeId = 123
      delete from [Umbraco].[dbo].cmsContentVersion where ContentId = 123
      delete from [Umbraco].[dbo].cmsContent where nodeId = 123
      delete from [Umbraco].[dbo].umbracoNode where id = 123
  • Ingmar Hoogendoorn 1 post 25 karma points
    May 23, 2011 @ 10:13
    Ingmar Hoogendoorn
    4
    I have the same issue. I currently have 5300 items in my recycle bin, due to testingt auto import stuff within Umbraco 4.7.
    I cleaned it up with the following sql:
    DECLARE @nodeId int
    DECLARE node_cursor CURSOR FOR
    SELECT Id
    FROM umbracoNode
    WHERE ParentId = -20
    OPEN node_cursor;
    FETCH NEXT FROM node_cursor
    INTO @nodeId;
    WHILE @@FETCH_STATUS = 0
    BEGIN
        delete from [dbo].cmsDocument where nodeId = @nodeId
        delete from [dbo].cmsContentXml where nodeId = @nodeId
        delete from [dbo].cmsPreviewXml where nodeId = @nodeId
        delete from [dbo].cmsPropertyData where contentNodeId = @nodeId
        delete from [dbo].cmsContentVersion where ContentId = @nodeId
        delete from [dbo].cmsContent where nodeId = @nodeId
        delete from [dbo].umbracoNode where id = @nodeId
        INTO @nodeId
    END
    CLOSE node_cursor;
    DEALLOCATE node_cursor;
  • ERPalmer 3 posts 23 karma points
    Jan 10, 2012 @ 21:25
    ERPalmer
    This SQL code works fine for me.
    Thanks Ingmar Hoogendoorn
  • Murray Roke 503 posts 967 karma points c-trib
    Aug 14, 2012 @ 05:33
    Murray Roke
    I'm guessing it's possible to have event handlers in your code which should fire when deleting items from the recycle bin?
    Obviously in this case they won't fire :-]
