  • dominik 711 posts 733 karma points
    Feb 25, 2011 @ 11:31
    dominik
    create continent specific country lists
    Hello
    What is the best way to do the following:
    I need continent specific language lists :
    For example for Europe:
    Austria
    Belgium
    Feb 26, 2011 @ 09:00
    Hi Dominik
    I think that depends on the use case...
    Should it be possible to update the lists within Umbraco?
    Feb 28, 2011 @ 07:52
    dominik
    Hi Jan,
    yes this would be nice if this is possible.
    So they can add and remove countries from specific lists.
    I looked a little bit into the datatypes but did not find anything.
    Feb 28, 2011 @ 08:01
    Hi Dominik
    Then I would consider to make a repository for this in the "Content" section "Called countries" or something like that and then have a structure like this
    Continents
       - America
       - Africa
       - Asia
       - Europe
         - Belgium
         - England
         - Germany
         - Etc.
    Does this makes sense?
    Feb 28, 2011 @ 08:14
    dominik
    yes but how i get all these countries inside a template.
    SO what i need exactly are some links like "Europe" "America"
    And if I click on any link the corresponding countries should appear without reloading page
    Feb 28, 2011 @ 09:47
    dominik
    So Here is a screenshot:
    I created the following:
    Now i need a xslt script which lists all countries of a specific region (for example"Europe")
    How can this be done?
    If i click "America" all Country Items from "America" should appear
