You find the nodeid in Umbraco backoffice by either looking at a specific document in the "properties" tab - Here you can see the ID.
You can also just hold your mouse over a specific node and look in the lower left corner. Here you'll also see the ID of the node.
But it's never a good idea to use hardcoded ID's in the code so I think you should be able to access the ID of the current node the macro is being used on by writing something like this:
Node node = Node.GetCurrent().id; This should give you the id of the current node, so you can then pass the "node" to the
Document doc = new Document(node);
Does this make sense to you? (I'm not that skilled at C# :))
Read Textbox datatype value in usercontrol
Hi There,
I have created a Textbox datatype called "EmailAddressContact "
now I want to read EmailAddressContact .Text in my UserControl code.
Your help is greatly appreciated
Regards
Sword
Hi praveen
I think you might find this helpfull then: http://our.umbraco.org/wiki/reference/api-cheatsheet/modifying-document-properties
Here you can also see how to create new nodes using the API etc.
Hope this helps.
Hi Jan
Many thanks for the reply and the solution
can you please tell me how do I get the document id (1029)
Document doc = new Document(1029);
I think i need to do the follwing to read value of the document property
string emailtext = doc.getProperty("EmailAddressContact ").Value ;
Please let me know, and many thanks for your help.
Kind Regards
Hi praveen
Is this resolved? Did you able to use the value of your custom doctype? I need to do similar stuff so...
