HiAfter I upgraded to 4.5.2 almost everything work exept an gallaery I have and it this code snippet that doesent work...
<xsl:for-each select="$currentPage/node [string(data [@alias='umbracoNaviHide']) != '1']"> <div class="Item"> <!-- get first photo thumbnail --> <a href="{umbraco.library:NiceUrl(@id)}"> <img src="{./data [@alias='ThumbImage']}" width="90" height="90" alt="{@nodeName}"/> </a> </div></xsl:for-each>
this is almost certainly due to the xml schema changing
try...
<xsl:for-each select="$currentPage/* [@isDoc and string(umbracoNaviHide) != '1']"> <div class="Item"> <!-- get first photo thumbnail --> <a href="{umbraco.library:NiceUrl(@id)}"> <img src="{concat(substring-before(umbracoFile,'.'), '_thumb.jpg')}" width="90" height="90" alt="{@nodeName}"/> </a> </div>
</xsl:for-each>
i'm not entirely sure about the img src i'm going to just check this further...
In the above is ThumbImage a generic property of the document type or is it using the thumbnail made by umbraco?
Hiits a generic property that I made..Its an old gallery where they uploaded an thumbnail and one bigger picture,,,
The old code look like this and I listed all thumbnails on that level
Now I try with this code after upgrading
<xsl:for-each select="$currentPage/* [@isDoc and string(umbracoNaviHide) != '1']"> <div class="Item"> <!-- get first photo thumbnail --> <a href="{umbraco.library:NiceUrl(@id)}"> <img src="{concat(substring-before(umbracoFile,'.jpg'), '')}" width="90" height="90" alt="{@nodeName}"/> </a> </div></xsl:for-each>
I want <img src="filepath/filename + extension" .....
/Henrik
Does ThumbImage contain this?
Can you just write...
<img src="{ThumbImage}" width="90" height="90" alt="{@nodeName}"/>
The new schema is so much easier to read when you get used to it :)
Perfect it works...How about this one
Its so I can step from first to last picture
<xsl:if test="count($currentPage/preceding-sibling::node) > 0"><a href="{umbraco.library:NiceUrl($Previous)}">« Föregående</a></xsl:if>
/H
After upgrading to 4.5.2
<div class="Item">
</a>
</xsl:for-each>
try...
<div class="Item">
</a>
</xsl:for-each>
<div class="Item">
</a>
<div class="Item">
</a>
</xsl:for-each>
/Henrik
Perfect it works...
How about this one
« Föregående
</a>
</xsl:if>
/H
