I have two identical copies running on two servers. On my dev server, all works correctly. On my staging server, I am having hostname issues. Instead of http://my.xyz.com, I am getting http://www.my.xyz.stghttp//my.xyz.stg when navigating to my.xyz.com. I've checked obvious settings in Umbraco. What am I missing?
Hostname Issues
Hi Connie,
Can you give a bit more information about the problem please? Is it the links on the front end that are wrong, or is it in the back end (or both)?
It turned out to be an issue with the Modify WWW package. I had to modify it as it was wanting to add www to my other third level domain.
FYI, I can't close this issue as resolved if the forum won't let me mark my reply as the solution.
