I'm using V4.0.4.2 on Net 2.0 with Umbraco Membership rather than Asp.net Membership becasue it's the only way I've been able to get YAF running inside Umbraco.
I want to register members programmatically to add some extra functionality but I can't get this to work. Here's my code:
using System; using System.Collections.Generic; using System.Web; using System.Web.UI; using System.Web.UI.WebControls; using umbraco.cms.businesslogic.member;
namespace MyApp.usercontrols { public partial class RegisterBeta : System.Web.UI.UserControl { public void Page_Load(object sender, EventArgs e) {
When I try to build or compile this (using VS 2008) I get the following error:
"The type or namespace name 'BusinessLogic' does not exist in the namespace 'MyApp.umbraco' (are you missing an assembly reference?)... "
I have umbraco.dll, cms.dll and business.dll all referenced and that seems okay because there is no error in the header statement "using umbraco.cms.businesslogic.member;" also I can see each of the subordinate namespaces in Intellisense as I type it. When I type 'umbraco' inside the partial class, however, all I get is 'schemas'
This has me at my wits end because I'm badly behind on a project and I just can't see what the problem is. I'd greatly appreciate anyone throwing any light on it.
This is probably a stupid question, but I'm asking anyway...have you right clicked where the error highlight in the code is to see if VS is able to resolve this automatically?
I eventually abandoned this and went with YAF running as a separate application. Seems a big gap to me that there is no up to date guide to integrating YAF and Umbraco latest versions, Dawoes's instructions at http://dawoe.blogspot.com/2009/02/intergrate-yet-another-forum-193rc2.html were great for earlier versions and has been deservedly promoted across the Net but they are well past their Sell by Date now.
"BusinessLogic missing" Error
using System;
using System.Web;
protected void RegisterMember()
string userName = txtUserName.Text, password = txtPassword.Text, email = txtEmail.Text;
MemberType regMemberType = MemberType.GetByAlias("Registered");
Member newMember = Member.MakeNew(
userName,
regMemberType,
new umbraco.BusinessLogic.User(0));
newMember.Email = email;
newMember.Password = password;
newMember.Save();
Hi Martin
Tried that, no good.
