  • Phillip Ng 148 posts 250 karma points
    Mar 09, 2011 @ 00:28
    Phillip Ng
    Blog for Umbraco: BlogListPosts not displaying anything
    I hate to start another thread about my problem with the package, but I am reaching the end of my rope. Installed the package, then got xslt errors sitewide, wherein I deleted the "\bin\" in the umbracoExtensions config file. XSLTs on other pages worked, but not on my blog page, but I moved forward. To follow the site structure, I moved the blog as a child of the home page, but couldn't publish posts easily. Another thread suggested I preview the page, then publish, so that solution, albeit a little troublesome, worked. Now, two problems I can't seem to find solutions for. The bloglistposts.xslt doesn't render anything on the blog page despite how my files are stuctured. The sidebar has navigation-by-level xslt and it displays links to the children of blog.aspx, so they are there, the xslt just isn't transforming them correctly? Also, the page still shows "error parsing Error parsing XSLT file: \xslt\Blogpages.xslt," blogcomments, and blogcategories. The trace states "value too large or too small for int32" but I can save the xslts just fine. Any ideas or suggestions would be greatly appreciated! Thanks in advance!
    Phil
    Mar 10, 2011 @ 18:34
    Phillip Ng
    Fixed, I think. Needed to install  Blog4Umbraco_2.0.26_for_4.5 package instead of Blog4Umbraco_2.0.26
