  • dillorscroft 198 posts 192 karma points
    Mar 11, 2011 @ 16:16
    dillorscroft
    Ultimate Picker not working
    I've used Ultimate Picker with 4.0.4.2 for a really long time.  18 months or so.
    I've only recently upgrade to the new schema and on a fresh install have tried to use the picker but nothing shows in the drop down at all.
    I'm using v4.5.2 with the .net 4 config
    On one property type using ultimate picker I get absolutely nothing rendwered on screen and another it's an empty listbox.
    Really can't see what I could have done wrong.  Everything is published and the source id's are correct.
    DC
    Mar 11, 2011 @ 17:11
    dillorscroft
    Really stuggling on this one.  Eating up hours....
    Mar 12, 2011 @ 13:08
    What does your XSLT code look like? Are you sure there are no typos in it? The tricky part when changing to the new schema and all is that you will not get any errors if there is some leftover from the old schema. Then there is just nothing that gets rendered, which can be very frustrating.
    Do you get anything returned if you just make value-of on the property that contains the selected node?
  • Tom Hare 49 posts 81 karma points
    Mar 14, 2011 @ 12:43
    Tom Hare
    I'd recommend trying out uComponents if you can't find a solution to your schema problems. There are several 'picker' datatypes including the Multi-node Tree Picker which I have found to be excellent.
    http://our.umbraco.org/projects/backoffice-extensions/ucomponents
    Tom
