As you understand form header i have problem afteri uploaded site on live serevr. the problemis when i open any windows in tinymce editor which should open in pop-up it just show the content below the formnot in pop-up.
The other pop-up windows in umbraco are forking fine. (for example about :)) My version of umbraco : v 4.6.1
Update: I haveplayed with tiny_mce_popup.js which is located in 'umbraco_client/tinymce3/'. There is a row :
// Uncomment and change this document.domain value if you are loading the script cross subdomains
//document.domain = 'domain.com';
i have uncommented the second row and changed domain to my name whithout "www" , and it's even worth: data which should apear in pop-up. and were displayed below form, disappear at all.
Found a solution my self. :) just got the new version of umbraco from codeplex (4.7) and copyed folder tinymce3 to the live server(umbraco_client) instead of old one. Now everything works.
TinyMCE pop-up problems on live site
Hi.
On localhost everything works fine.
Please advice,
Thank you.
may be somebody had such case .
Thank you.
