I just installed Standard Site from Umbraco Packeges. Could you please tell me how I can change images in the slideshow on the home page of the site?
Thank you.
Hi Berdia
Is suposse it's the package by Chris Koiak you're reffering to?
Then it's a matter of adding more nodes under the "Slideshow" folder?
hi Jan,
Yes, that what I am refering to. I can't see "Slideshow" folder under the root. I presume it is a subfolder. Where do install packages go when you install them, which folder? Where can I find "Slideshow" folder?
Jan,
Never mind, I found it.
Was just about to post a thourough answer but seems it's not necessasery anymore - glad to hear you figured it out.
How to change images in slideshow?
Thank you.
Hi Berdia
hi Jan,
Thank you.
Jan,
Thank you.
Hi Berdia
