  • E.J. Brennan 73 posts 114 karma points
    Mar 14, 2011 @ 18:26
    E.J. Brennan
    many to many relationship in umbraco
    OK, the title isn't exactly accurate, but this is what I would like to do - I know I can do it using custom database tables and .net, but wondering how it might be accomplished in a pure umbraco fashion.
    Let say I am doing an intranet app for a small company. Each department will get a page, and each employee will have his or her own page with some contact information. Each department page will have some information about the department, and then a list of the employees that work in the department - and then a user can click thru and get the details about an employee. All of that I can do easily with various document types and standard navigation.
    Now say I have a situation where an employee can work for more than one department, and on each department page I would like a list of each of the employees in that department to show, so some employees will appear in 1-N departments.
    This would be trivially easy to do with my own set of sql tables and custom controls (I'd add a 'linking' table that relates departments to people - but how might this be accomplished without restorting to asp.net.  I suppose I could re-use some of the logic that relates blog posts to tags, but is there a different/better way?
    Suggestions?
  • Hendy Racher 863 posts 3849 karma points MVP 2x admin c-trib
    Mar 14, 2011 @ 18:43
    Hendy Racher
    How have you currently structured your content tree ? I'm guessing you perhaps have employee nodes beneath dept nodes ?
    If this is the case how about splitting them into:
    Departments
    - Dept 1
    - Dept 2
    Employees
    - Emp 1
    - Emp 2
    and then using a multipicker on the either the Dept nodes to choose the associated people, or on the Emp nodes to choose the departments ? (you can also wire up the relation types API to enable speedy reverse lookups - which I'm guessing would be very similar to how you where thinking for the SQL lookup table)
    HTH,
    Hendy
